Ha os on X86, absolute beginner. I don’t mind full reset to default, please help.
I can only access via keyboard.
This did not work
I don’t use haos but you could try
pwd
just to see what dir you are in.
so you are in root dir /.
Do you know some basic linux commands? Like
ls -l
to list directory tree. I don’t know where config directory is in haos try to find it. Or try to find configuration.yaml file with something like
find / -iname configuration.yaml
I don’t know what you did, and you didn’t explained much.
Basically you have two options. Use this, spend some time to learn some basic commands. You have a lot of info on the net or just reinstall.
In debian with supervised installation config dir is where configuration.yaml is.
I was trying to set up remote access to HA via duckdns.org, I added local, external urls, and since then I can only acces HA via keyboard/cli
So you messed up configuration.yaml file. No problem. Go to that directory
cd /mnt/something
and open configuration.yaml file with editor. Now I don’t know what editor you have. Try mc command for midnight commander, maybe it’s installed by default. If it isn’t try vi like
vi configuration.yaml
For input use “i”. When you finish editing press esc, than : and letters wq. This mean save.
You have to comment out lines you put in configuration.yaml file. You do that with # sign in the begging of line.
That is how you will revert your changes. And reboot in the end.
I don’t see anything on this picture. What did you do?
You have a lot of info online how to edit file with vi. So check this out. You just have to comment out your changed.
You don’t have to do it now. Leave it for tomorrow.
This command I did.
Ok and with letter i you can access editor mode, meaning you can change file.
Esc exit editor
: wq save changes and quit.
Look on the net for command on exiting vi editor.
If you saved changes check file with cat configuration.yaml
Ok you probably can’t edit file because you have to be root. Do the same just with sudo
sudo vi configuration.yaml
It will ask you for root password so type it in.
