Script and Automation
So i am trying to get this automation to work but i am struggling. My google home announces it the first time but I can’t get it to repeat with the second script. Am i missing something?
- alias: "Auto Turn Off Water Alert Switch"
    - platform: numeric_state
      entity_id: sensor.water_heater_water_sensor_flood
      below: 2
      entity_id: sensor.sump_pump_water_sensor_flood
      below: 2
      entity_id: sensor.laundry_room_water_sensor_flood
      below: 2
        entity_id: input_boolean.water_alert
- alias: "Alert - Water Heater"
      above: 1
    - service: notify.GrangerHome
        title: Water Heater Alert
        message: Your Water Heater is leaking in the basement
          priority: 2
          timestamp: true
          retry: 30
          expire: 43200
    - delay: 00:00:03
    - service: script.turn_on
      entity_id: script.water_alert_tts
- alias: "Alert - Sump Pump"
      above: 1
        title: Sump Pump Alert
        message: Your Sump Pump is broken in the basement
          priority: 2
          timestamp: true
          retry: 30
          expire: 43200
    - delay: 00:00:03
- alias: "Alert - Laundry Room"
      above: 1
        title: Laundry Room Alert
        message: There is water in the laundry room
          priority: 2
          timestamp: true
          retry: 30
          expire: 43200
    - delay: 00:00:03
1st script:
alias: Water Alert TTS
    sequence:
      - service: tts.google_say
        entity_id: media_player.living_room_home
        data_template:
          message: >
            {% if state.(sensor.water_heater_water_sensor_flood) | float > 1 %}
              Your basement has water in it.  Go check it out now
            {% elif state.(sensor.sump_pump_water_sensor_flood) | float > 1 %}
            {% elif state.(sensor.laundry_room_water_sensor_flood) | float > 1 %}
              Your laundry room has water in it.  Go check it out now
            {% else %}
              Something water sensor has tripped but I cannot pinpoint where.
            {% endif %}
        entity_id: script.loop_water_alert
2nd Script
alias: Loop Water Alert TTS
    sequence:
      - delay:
            # Delay for voice
            seconds: 5
      - condition: state
        state: 'on'
Maybe Entity_id for script 2 is wrong in script 1:
entity_id: script.loop_water_alert_tts
Kr
J
Your spacing is way out on both scripts too, looks like you have four spaces at the start of the lines instead of two.
So I got a little closer. There was some things wrong in that first post. I guess I have been trying too many things. It appears that it will run the automation ok but never goes into the script to run.
      below: 2
      below: 2
      below: 2
    - service: input_boolean.turn_off
      above: 1
          priority: 2
          timestamp: true
          retry: 30
          expire: 43200
      above: 1
          priority: 2
          timestamp: true
          retry: 30
          expire: 43200
      above: 1
          priority: 2
          timestamp: true
          retry: 30
          expire: 43200
- alias: "Alert - Water Sensor Tripped"
      above: 1
      above: 1
      above: 1
    - platform: state
      to: 'on'
    - service: media_player.turn_on
    - service: media_player.volume_set
        volume_level: 0.65
1st Script:
sequence:
    data_template:
      message: >
        {% else %}
        {% endif %}
2nd Script
sequence:
  - delay:
        # Delay for voice
        seconds: 5
  - condition: state
    state: 'on'
Any ideas on this?
I would do…
  - service: script.water_alert_tts
and
  - service: script.loop_water_alert
I’m not sure it will make much difference tho’ as I think you can use both ways, however you might have to format it differently…
So i tried it all three of these ways and none of them work. I must be missing something. I know it is executing the automation because I can hear the google home beep.
I couldn’t get your data template to work in dev tools, however if it’s like this it works…
        {% if states.sensor.bedmaxtemp.state | float > 1 %}
        {% elif states.sensor.bedmintemp.state | float > 1 %}
        {% else %}
        {% endif %}
Obviously I’ve used my own sensors :stuck_out_tongue:
As for the scripts, mine work either way that I posted, however I don’t think you can mix and match. I think if you use script.turn_on you need the data part and if you use the service call directly you don’t add enitity_id below it.
