How can I apply the sequence in this script to multiple entities ?
Without “multiple: true” the script works as expected
But looking for a way apply the sequence to multiple selected entities.
I do get the selector and can select multiple entities but it fails to run and returns
" Error rendering data template: TemplateError: Must provide a device or entity ID"
saw “for each” , “loop” options but not totally sure how to implement correctly and looking for advice.
Thank you,
alias: THERMOSTATS sinope set floor control mode ZHA
fields:
entity_id:
required: true
description: Entity ID of your thermostat
selector:
entity:
multiple: true
filter:
domain: climate
mode:
required: true
description: Select desired option
default: ambiant
selector:
select:
options:
- floor
- ambiant
mode: single
icon: mdi:account
sequence:
- service: zha.set_zigbee_cluster_attribute
ieee: >-
{{ device_attr(entity_id, 'identifiers') | selectattr(0,'eq','zha') |
map(attribute=1) | first }}
endpoint_id: 1
cluster_id: 65281
cluster_type: in
attribute: 261
value: "{{'1' if mode == 'ambiant' else ('2' if mode == 'floor' else '1')}}"
