Hello everyone,
I just thought of an idea while sitting at work and have no idea on the script or coding to do this but.
Usually my wife and I will walk the dogs after 9pm but lately we haven’t been doing it and need to get back in the habit. I thought it would be cool if the script sees that we haven’t left the house together in the last 2 days between 9p-11a to shout out for us to walk the dogs.
This certainly would be the cheapest/free option besides buying expensive dog collar tracking devices. Would love some help on getting this running
input_boolean:
failed_day_one:
failed_day_two:
binary_sensor:
platform: template
sensors:
both_in:
value_template: "{{ states('device_tracker.YOU') == 'home' and states('device_tracker.WIFE') == 'home' }}"
automation:
- alias: Failed day counter
platform: time
at: '21:00:00'
service: homeassistant.turn_on
data_template:
entity_id: >
{% if is_state('input_boolean.failed_day_two' , 'on') %} script.walk_the_dog
{% elif is_state('input_boolean.failed_day_one' , 'on') %} input_boolean.failed_day_two
{% else %} input_boolean.failed_day_one {% endif %}
- alias: Probably walked the dog
platform: state
entity_id: binary_sensor.both_in
to: 'off'
condition:
condition: time
after: '21:00:00'
before: '23:00:00'
service: homeassistant.turn_off
entity_id:
- input_boolean.failed_day_one
- input_boolean.failed_day_two
script:
walk_the_dog:
sequence:
- service: light.turn_on
entity_id: light.living_room
color: red
- service: notify.YOU
message: "Walk the dog!"
- service: notify.WIFE
Or something similar.
@anon43302295 you are amazing! Can’t thank you enough for the time that you spent on this.
I can edit code and manipulate it but would never be able to do what you did. Though I do get an error that I need to look through and it seems to do with the automation.yaml file that I have that the configuration file is linked to. The error I get is this.
2018-08-28 20:30:40 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: expected a dictionary for dictionary value @ data['action'][0]['data_template']. Got None. (See /home/christoph/.homeassistant/configuration.yaml, line 163). Please check the docs at https://home-assistant.io/components/automation/
I would have never thought of that approach. Brilliant!
Ahhh… There’s just a small typo…
data_template: >
Should not have > on the end…
Then add a line under that that says:
entity_id: >
No worries
Hopefully you’ve fixed this now from @swiftlyfalling 's note, but I’ve modified the code in my original post to fix the error.
Hope the dogs enjoy it
Throwing up no more errors in my HA. Thanks again to you and @swiftlyfalling
