The following code checks through a number of sensors to see if any are open. If any are open the “all_closed” is set to false and a message is created to tell me which sensors are open.
The bug is that I can see in the first loop that “all_closed” is evaluating to false (as I have some sensors open when testing) in the loop be is somehow evaluating to true before it choses what do. I assume it is re initialising the “all_closed” variable at the start of the script but I can’t see how
alias: Check Sensors Status
variables:
message: ""
all_closed: true
sensors:
- entity_id: binary_sensor.s_up_back_win
alias: Back Windows
- entity_id: binary_sensor.s_back_gar_door
alias: Rear Garage Door
- entity_id: binary_sensor.s_toilet_win
alias: Bathroom Window
- entity_id: binary_sensor.s_dine_play_room
alias: Dining Room Playroom Windows
- entity_id: binary_sensor.s_up_front_win
alias: Upstairs Front Windows
- entity_id: binary_sensor.s_main_gar_door
alias: Main Garage Door
- entity_id: binary_sensor.s_side_gar_win
alias: Side Garage Window
- entity_id: binary_sensor.s_kitchen_win
alias: Kitchen Window
- entity_id: binary_sensor.s_living_room
alias: Living Room Window
- entity_id: binary_sensor.s_master_win
alias: Master Bedroom Window
- entity_id: binary_sensor.s_piz_area_door
alias: Pizza Area Door
sequence:
- repeat:
for_each: "{{ sensors }}"
sequence:
- choose:
- conditions:
- condition: template
value_template: "{{ is_state(repeat.item.entity_id, 'on') }}"
sequence:
- variables:
all_closed: false
- data:
title: Checking sensors...
message: "{{ repeat.item.alias }} is open. {{ all_closed }}"
action: persistent_notification.create
- data:
entity_id: input_text.open_sensors_message
value: >
{{ message }}{{ repeat.item.alias }} is open.. compiled
message. {{ all_closed }}
action: input_text.set_value
- action: notify.persistent_notification
metadata: {}
message: Status of all_closed variable .. {{ all_closed }}
- choose:
- conditions:
value_template: "{{ all_closed }}"
sequence:
entity_id: input_boolean.all_sensors_closed
- service: persistent_notification.create
title: Sensor Check Result
message: All sensors are closed.
- conditions:
value_template: "{{ not all_closed }}"
sequence:
- service: input_boolean.turn_off
message: "{{ states('input_text.open_sensors_message') }}"
