I created a script to trigger an emergency mode. Basically, if you long-press a button, it will do the following steps:
- Set the emergency mode counter to 1
- Create a scene ‘before’ of all lights
- Turn on all lights to full brightness
A second long-press of any button will reset the lighting to the previous state and reset the emergency mode counter to 0.
What I want to do is to be able to do a single-press on any button when the emergency mode is active to reset it instead of the long-press.
Would there be an easy way to do this, or do i need to create a script/blueprint that would be used on every button?
