I want to run a script that has as condition switch.
The tested condition is a loop. If one item returns true, the condition is fulfilled.
In all other cases default condition should be used.
The template holds a variable named ‘player’, this script is called via an automation that passes the exact player entity_id to the script.
When testing the template from development tools, the loop seems to function correct.
It returns ‘true’ when one of the players in the sync group is already playing.
But when I put this inside the script, the default condition is always chosen.
Any help would be appreciated.
squeezebox_play_music:
alias: Play music
sequence:
- service: squeezebox.call_method
data_template:
entity_id: '{{ player }}'
command: power
parameters: 1
data_template:
command: mixer
parameters:
- volume
- '8'
- choose:
- conditions:
- condition: template
value_template: >
{% for entity_id in state_attr(player, 'sync_group') %}
{% if states(entity_id) == 'playing' %}
true
{% endif %}
{% endfor %}
sequence:
data_template:
command: playlist
parameters:
- play
- '4'
default:
data_template:
command: playlist
parameters:
- play
- MyPlaylist
- '4'
