Hello community,
I am relatively new to Home Assistant, I have integrated my FritzBox, my Kostal inverter PV system and my Viessmann Vitocal 251 heat pump.
The monitoring and also the control of the Fritz heating thermostats depending on the volume flow and the outside temperature works so far.
Now I would like to increase the heating temperature via the enitaet “climate.e3_vitocal_heating” e.g. from 22°C to 23°C, this should be done via a script.
The changeover in the interface works without any problems.
Can anyone give me a tip on how to implement this?
Thank you very much
Greetings Christopher
