[Script] Cycle fan speed
Hey all, off the bat, apologies if this has been posted before (it was fairly trivial, I’d be surprised it if hasn’t, although I wasn’t able to find anything when searching).
This is a simple script that can be called to increase or decrease the speed of a fan, simulating the traditional physical pull-chain. Since this is a script, you can choose how you trigger it from an automation (click a Zigbee or Z-Wave button, trigger by presence, sync with a light, whatever you want!)
You can use two different modes of stepping by toggling the “Start on High” option during setup:
  • off → high → medium → low (common on most pull chains)
  • off → low → medium → high (my personal preference)
While most fans are either on-off (no need for this script then) or three-step motors, this script makes no assumptions about step intervals and can be used on fans with any number of steps.
Blueprint
blueprint:
  name: "Cycle fan speed"
  description: >-
    A script that increments or decrements the speed of a fan.
  domain: script
  source_url: https://github.com/nwithan8/configs/blob/02229006680ccb20c654a745b907c768e9fee9d7/home_assistant/blueprints/scripts/cycle_fan_speed.yaml
  input:
    fan:
      description: "The fan entity to change the speed of"
      selector:
        entity:
          domain:
            - fan
            - group
          multiple: false
    start_high:
      name: "Start on high"
      description: "Start with the highest speed from off (off -> 3 -> 2 -> 1 instead of off -> 1 -> 2 -> 3)"
      selector:
        boolean:
# Only single, otherwise could flood with attempts
mode: single
fields: {}
variables:
  fan: !input "fan"
  start_high: !input "start_high"
sequence:
  - variables:
      current_speed: '{{ state_attr(fan, "percentage") }}'
  - choose:
      - conditions:
          - alias: "Fan is off"
            condition: template
            value_template: "{{ current_speed <= 0 }}"
        sequence:
          - if:
              - alias: "Should start on highest speed"
                condition: template
                value_template: "{{ start_high }}"
            then:
              - service: fan.set_percentage
                  percentage: 100
                  entity_id: "{{ fan }}"
            else:
              - service: fan.increase_speed
      - conditions:
          - alias: "Fan is at max speed"
            condition: template
            value_template: "{{ current_speed >= 100 }}"
        sequence:
          - if:
              - alias: "Started on highest speed"
                condition: template
            then:
              - service: fan.decrease_speed
            else:
                  percentage: 0
    default:
      - if:
            condition: template
        then:
        else:
Install
  1. Click the “Import Blueprint” button above and follow the on-screen instructions to import the blueprint into your Home Assistant.
  2. Create a new script using the blueprint (Settings → Automations & Scenes → Scripts tab → “Add Script” → Select “Cycle fan speed” from the list)
  3. Fan: Select the fan or fan group entity you wish to control
  4. Start on high: Determine the fan speed order:
    • On: Off → High → Medium → Low
    • Off: Off → Low → Medium → High
Usage
Call the script manually or from an automation. No need to keep track of the fan speed in a separate entity or helper.
Release History:
1.0.0 (May 24, 2024):
  • Initial Release
