Hi all,
I have prepared a simple script to open a roller shutter a certain amount. Then I considered I wanted to control that amount independently, so I created a helper number variable. The problem is I cannot use that variable on the script - is this a known limitation or am I missing something obvious?
Current, working setup:
alias: Garage vent left
sequence:
- device_id: 3dfec9b52174ac45d611ee5be0e5a7db
domain: cover
entity_id: cover.sp25_2_gdl
type: set_position
position: 26
mode: single
icon: mdi:garage-alert
Intended script - not working (despite trying a few variations of the syntax):
sequence:
domain: cover
type: set_position
position: ' {{ states("input_number.garage_vent_percentage")|int }} '
mode: single
The error is Message malformed: value must be one of ['close', 'close_tilt', 'open', 'open_tilt', 'stop'] for dictionary value @ data['type']
Any suggestions? Is this not possible?
Thanks in advance;
