Does anyone have an example of a script that has a sequence of events in it that works? I have found several different examples in the documentation and in the example files. None of them seem to be the same syntax. I think I have tried each of them over the past week and still can’t seem to get the scripts to run. I have simplified mine to the following.
script:
Morning:
alias: "Good Morning"
sequence:
- service: switch.turn_on
entity_id: switch.stairway_switch
# - delay:
# minutes: 1
# - service: light.turn_on
# data:
# entity_id: group.stair_lights
# brightness: 128
# color_name: white
# - service: switch.turn_off
# data:
# entity_id: switch.stairway_switch
and all I get in the home-assistant.log file is the following.
Nov 23 20:06:55 hass hass[27517]: #033[32m16-11-23 20:06:55 INFO (MainThread) [homeassistant.components.http] Serving /api/services/homeassistant/turn_on to 192.168.2.105 (auth: True)#033[0m
Nov 23 20:06:55 hass hass[27517]: #033[32m16-11-23 20:06:55 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service=turn_on, service_call_id=1975917360-11, domain=homeassistant, service_data=entity_id=script.morning>#033[0m
Nov 23 20:06:55 hass hass[27517]: #033[32m16-11-23 20:06:55 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service=turn_on, service_call_id=1975917360-12, domain=script, service_data=entity_id=['script.morning']>#033[0m
Nov 23 20:06:55 hass hass[27517]: #033[32m16-11-23 20:06:55 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=1975917360-12>#033[0m
Nov 23 20:06:55 hass hass[27517]: #033[32m16-11-23 20:06:55 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=1975917360-11>#033[0m
