I have two scripts, where both have the same fields.
These fields were added thru the UI from the first script.
In the second script I’ve copied the yaml and made changes to work similarly for other devices.
However, the field for one appears on UI, and the second no.
I’m considering this a defect or is there something I am missing here?
alias: Ar Quente Augusto (script)
description: |-
liga ar quente, conforme temperatura de parametro
muda pra ventilação/desliga , conforme temperatura de parametro
sequence:
fields:
desligar_as:
selector:
datetime: {}
add_mais_1_hora:
selector:
number:
min: 1
max: 100
name: Executa por +1 hora
mode: restart
alias: Boiler automatico v2 (script)
sequence:
mode: restart
icon: mdi:water-boiler-auto
fields:
desligar_as:
selector:
datetime: {}
add_mais_1_hora:
selector:
number:
min: 1
max: 100
description: >-
Pode receber 2 parametros, data/hora ou se adiciona +1 hora.
Fica em loop conferindo a temperatura do boiler minuto a minuto até dar o
tempo parametrizado
Checked the content of the issue report and not sure if is the same, since I didn’t copied the script by the UI, I’ve copied the yaml and pasted it over a new script skeleton.
I don’t know about the flow of the development releases, I saw now the code was merged only 9 hours ago, so, is there any chance to be published on version 2024.9.2 ?
