Script Files No Longer Working
Did something change with the script files between 0.64 and 0.67.1 Mine no longer seems to be working.
Error running command: bash /bash/take_doorbell_snapshot.sh, return code: 127
It seemed to work in previous versions however now it is not. From 0.65.0 on I have seemed to have a lot of issues with multiple components (Asus router, honeywell (which seems to have gotten fixed in 0.67.1), MyQ garage, and google chromecast)
127 is command not found - what’s the script?
I know there is probably a more efficient way to write this but I am no expert and it works. Well at least it did.
 #!/bin/bash
    outdir=/Cameras/Front_Porch
    if [[ ! -d "$outdir" ]]; then
      mkdir -p "$outdir"
    fi
    ffmpeg -y -i rtsp://CameraName:[email protected]/h264Preview_01_main -frames 2 -strftime 1 /Cameras/Front_Porch/Front_Door-%Y-%m-%d_%H-%M-%S.jpg
    cd /Cameras/Front_Porch
    ls > /Cameras/Front_Porch/Extra/contents
    cd
    tail -n 1 /Cameras/Front_Porch/Extra/contents > /Cameras/Front_Porch/Extra/lastfile
    var1="/Cameras/Front_Porch/Extra/lastfile"
    echo $var1 > /Cameras/Front_Porch/Extra/echotocompare
    var2=$(cat $var1)
    echo $var2 >> /Cameras/Front_Porch/Extra/echotocompare
Maybe permissions issue on /cameras/ ?
What’s the shell command you’ve got?
alias: Take Doorbell Snapshot
sequence:
  - service: shell_command.take_doorbell_snapshot
I don’t think it is permissions because it was working previously.
But what is the shell command?
Sometimes permissions get accidentally changed, have a look at all the “can’t upgrade” threads kicking around.
Another random thought, have you whitelisted /camera/ ?
I am not sure which shell command it is. the only error i am grtting is
Error running command:bash /bash/take_doorbell_snapshot.sh, return code: 127
i verified the permissions. everything was set to 755
i have not whitelisted anything yet
Somewhere in your configuration you have an entry like…
shell_command:
  take_doorbell_snapshot: SOMETHING_HERE
Which we could do with seeing.
Under homeassistant try whitelisting /camera/, eg…
homeassistant:
  latitude: 1.2345678
  longitude: 1.2345678
  elevation: 100
  unit_system: metric
  time_zone: Europe/Paris
  whitelist_external_dirs:
    - /Camera
Here is my shell command.
take_doorbell_snapshot: 'bash /bash/take_doorbell_snapshot.sh'
Ok i think the shell command fixed it. I had to change the path for some reason as it was no longer pointing to the correct file. Thanks for the help. Now I will begin trying to fix my other issues.
