Script for setting input_select option
Trying to create a script to set the option of an input_select to a speciific value. What am I doing wrong?
set home status to sleep
  set_sleep_mode:
    alias: 'Sleep Mode'
    sequence:
      - service: input_select.select_option
          entitiy_id: input_select.status
          option: Sleep
Option: sleep should be option: ‘Sleep’
See a comparable script in this post:
Thanks for your help. I tried that but executing the script still leaves the input_select.status on ‘Normal’
see the detail:
form configuration.yaml
input_select:
  status:
    options:
      - Normal
      - Evening
      - Night
      - Sleep
    initial: Normal
from the script.yaml
  set_sleep_mode:
    alias: 'Sleep Mode'
    sequence:
          option: 'Sleep'
I trigger the script from the HA platfrom but the option remains at normal
I think the script should have data_template:, not data:
Only thing I see is spelling error on “entitiy_id”.
The only time you need data_template is if you are defining a template, which you are not.
Wow, apologies for being so blind about the spelling.
Thanks a lot
N
