I am trying to setup a script that will do the following when triggered from a button in the lovelace dashboard in the following sequence
When button is pressed it in LL dashboard it turns on output 1 for 0.5 seconds - ##Turns on device##
Wait for 60 seconds - ##waits for device to power/warm up##
Output 2 is then triggered for 0.5 seconds ##Select programmed drink##
4)Wait 90 seconds ##Makes the Drink##
Then trigger output 1 for 0.5 seconds ##Turns of Machine##
The reason for this is for my coffee machine, it wasn’t a ‘smart device’ but i have added a wifi relay board to the machine and connected the outputs to the coffee machine buttons. It needs time to power/warm up before before you can then select the drink you want.
Would someone be kind enough to help me with this script please?
I have tried doing it with the UI but cannot seem to build it up properly, so i have been reading the guide you attached and looking at examples of other peoples. Sorry if this is a basic question but its all a new learning curve to me, I have only really been doing it since the xmas break!
