Need a little help with a script, can’t seem to figure it out on my own so I’m coming here for help.
Script is:
#=== Script to irrigate a specific zone
#=== is passed:
#=== {{ cycle }}
#=== {{ zone }}
irrigate_specific_zone_request:
sequence:
# Update ui to show cycle is running
- service: homeassistant.turn_on
data_template:
entity_id: input_boolean.cycle{{ cycle }}_running
# Turn on master irrigation pump
- service: switch.turn_on
data_template:
entity_id: switch.master_pump
# wait 3 seconds for good measure to enable pressure in system
- delay: "00:00:03"
- service: script.irrigate_a_zone
data_template:
cycle: '{{ cycle }}'
zone: '{{ zone }}'
# Wait for script.irrigate_a_zone to end
- wait_template: "{{ is_state('script.irrigate_a_zone', 'off') }}"
# Update progress in ui
- service: input_text.set_value
data_template:
entity_id: input_text.cycle{{ cycle }}_current_zone
value: 'None'
- service: homeassistant.turn_off
data_template:
# Turn off master irrigation pump
- service: switch.turn_off
data_template:
the error it gives when checking config is:
Configuration invalid
Error loading /config/configuration.yaml: while parsing a block collection
in “/config/scripts.yaml”, line 18, column 7
expected <block end , but found '<block mapping start ’
in “/config/scripts.yaml”, line 40, column 8
line 18 is the first service after sequence
EDIT GOT IT FIGURED OUT HAD SPACING ERRORS. SORRY FOR THE WASTED SPACE, CAN ADMIN DELETE
