Can we have the ability to use icons with script, just as it works - for example - with input_boolean?
I would really like to change that dull script icon to something more meaningful:
Have you tried customizing : https://home-assistant.io/getting-started/customizing-devices/ ?
You’re right, of course! That worked perfectly:
Thanks and please close this request.
Reviving a very old thread here, but can you paste the code you put in customize.yaml? I’m having trouble figuring out what to use.
My scripts.yaml:
'1535688400424':
alias: Disarm Alarm
sequence:
- alias: ''
entity_id: alarm_control_panel.ha_alarm
service: alarm_control_panel.alarm_disarm
'1535688497607':
alias: Alarm - Arm_Home
sequence:
- data:
service: alarm_control_panel.alarm_arm_home
My Customize.yaml:
script.Disarm_Alarm:
icon: access-point
This does not change the script icon as expected.
Try
icon: mdi:access-point
Nope, that didn’t do it.
Do I have the correct syntax for the script?
That’s my script alias in scripts.yaml
Does the script work? Any errors in the log?
should work. Note the “mdi:” that @Tomahawk mentioned. Maybe try adding
friendly_name: Renamed Script Disarm
and check if the script is being renamed.
Not sure if your scripts.yaml is correct, indentation looks a bit broken. Make sure the script is working, first. Is it listed under “States” in “Developer Tools” section?
Try lover case for script.disarm_alarm:
The script does work.
Here is the listing under “states”
So I tried this code in customize.yaml
script.1535688400424:
That didn’t work. I also tried:
That didn’t work either
I do have this in my customize.yaml and it works. So the customizing works.
switch.wemo_mini:
friendly_name: Wall Tablet Charger
I do think it was working before for me but now it seems broken. All my scripts show up with the default icon.
The entity_id is script.1535688400424
, not script.disarm_alarm
(or `script.Disarm_Alarm), which is the one to use. However as explained in the docs:
New customize information will be applied the next time the state of the entity gets updated.
Run the script, and the icon should change.
