Does anyone have this scenario working (or let alone know if it can be done)? What I am trying to achieve is have an input select for a AVR that will send the IR codes based on the selection.
The below configuration loads, but it is not sending the IR code to change an input. Using the gui under broadlink call service I can successfully send the command to change input so I know they are working.
alias: Change Denon Input
sequence:
- service: broadlink.send_packet_192_168_2_63
value_template:
packet: >
{% if is_state("input_select.denon_input", "Kodi") %} - "JgDMAAoYCT0KGQoYCRkIGgkaCD0IPgoYCxgJPAo7CBsKGAkABfMKGQg9CBsIGgkaCD0IPQkZCRoIPQg9ChgJGgg9CjwKAAWsChkIPgoXCRoIGgkaCBsIPQk8ChgIGwc/CjsKGAoZCQAF8goaCjsJGQkaCRkJPAo7ChkIGgk8CTwJGggaCTwJPQoABa0JGQk8ChkIGgkaCBsIGgg9CjsJGggaCTwKPAoZChcJAAX0ChkKOwoZChgJGgk8CjsIGgkaCToMOwkZCRoIPQk8CgANBQAAAAAAAAAAAAAAAA=="
{% elif is_state("input_select.denon_input", "CD") %} - "JgDMAAoYCT0KGQoYCRkIGgkaCD0IPgoYCxgJPAo7CBsKGAkABfMKGQg9CBsIGgkaCD0IPQkZCRoIPQg9ChgJGgg9CjwKAAWsChkIPgoXCRoIGgkaCBsIPQk8ChgIGwc/CjsKGAoZCQAF8goaCjsJGQkaCRkJPAo7ChkIGgk8CTwJGggaCTwJPQoABa0JGQk8ChkIGgkaCBsIGgg9CjsJGggaCTwKPAoZChcJAAX0ChkKOwoZChgJGgk8CjsIGgkaCToMOwkZCRoIPQk8CgANBQAAAAAAAAAAAAAAAA=="
{% elif is_state("input_select.denon_input", "DVD") %} - "JgDMAAoYCT0KGQoYCRkIGgkaCD0IPgoYCxgJPAo7CBsKGAkABfMKGQg9CBsIGgkaCD0IPQkZCRoIPQg9ChgJGgg9CjwKAAWsChkIPgoXCRoIGgkaCBsIPQk8ChgIGwc/CjsKGAoZCQAF8goaCjsJGQkaCRkJPAo7ChkIGgk8CTwJGggaCTwJPQoABa0JGQk8ChkIGgkaCBsIGgg9CjsJGggaCTwKPAoZChcJAAX0ChkKOwoZChgJGgk8CjsIGgkaCToMOwkZCRoIPQk8CgANBQAAAAAAAAAAAAAAAA=="
{% elif is_state("input_select.denon_input", "IPOD") %} - "JgDMAAoYCT0KGQoYCRkIGgkaCD0IPgoYCxgJPAo7CBsKGAkABfMKGQg9CBsIGgkaCD0IPQkZCRoIPQg9ChgJGgg9CjwKAAWsChkIPgoXCRoIGgkaCBsIPQk8ChgIGwc/CjsKGAoZCQAF8goaCjsJGQkaCRkJPAo7ChkIGgk8CTwJGggaCTwJPQoABa0JGQk8ChkIGgkaCBsIGgg9CjsJGggaCTwKPAoZChcJAAX0ChkKOwoZChgJGgk8CjsIGgkaCToMOwkZCRoIPQk8CgANBQAAAAAAAAAAAAAAAA=="
{% elif is_state("input_select.denon_input", "ChromeCast Audio") %} - "JgDMAAoYCT0KGQoYCRkIGgkaCD0IPgoYCxgJPAo7CBsKGAkABfMKGQg9CBsIGgkaCD0IPQkZCRoIPQg9ChgJGgg9CjwKAAWsChkIPgoXCRoIGgkaCBsIPQk8ChgIGwc/CjsKGAoZCQAF8goaCjsJGQkaCRkJPAo7ChkIGgk8CTwJGggaCTwJPQoABa0JGQk8ChkIGgkaCBsIGgg9CjsJGggaCTwKPAoZChcJAAX0ChkKOwoZChgJGgk8CjsIGgkaCToMOwkZCRoIPQk8CgANBQAAAAAAAAAAAAAAAA=="
{% elif is_state("input_select.denon_input", "USB") %} - "JgDMAAoYCT0KGQoYCRkIGgkaCD0IPgoYCxgJPAo7CBsKGAkABfMKGQg9CBsIGgkaCD0IPQkZCRoIPQg9ChgJGgg9CjwKAAWsChkIPgoXCRoIGgkaCBsIPQk8ChgIGwc/CjsKGAoZCQAF8goaCjsJGQkaCRkJPAo7ChkIGgk8CTwJGggaCTwJPQoABa0JGQk8ChkIGgkaCBsIGgg9CjsJGggaCTwKPAoZChcJAAX0ChkKOwoZChgJGgk8CjsIGgkaCToMOwkZCRoIPQk8CgANBQAAAAAAAAAAAAAAAA=="
{% endif %}
Can it be done link this?
