I have a switch defined in my configuration.yaml, with on/off commands defined which work well when I switch the device on/off from the HA web page.
I have written a script to power cycle the switch, but when I activate the script (e.g. from the HA web page) nothing happens - the switch is not power cycled.
Any idea why this script does nothing:
power_cycle_study_cam:
alias: Power cycle study camera
sequence:
- service: switch.turn_off
entity_id: switch.study_cam
- delay:
seconds: 3
- service: switch.turn_on
get rid of the “data:” heading and decrease the indent of “entity_id: switch.study_cam” by two spaces. I know the documentation shows to use “data:” but I’ve only ever used it for lights which have additional data such as brightness, color, etc.
sequence:
- delay:
seconds: 3
The yaml validates so it’s not a formatting issue. Is that the name of the switch as seen on the services tab from the frontend? I’m assuming you reloaded scripts or rebooted HA after making the changes?
Hmmm…strange…there is a message saying “Command failed: curl -u …”
I also get that same message when I turn the switch on/off directly from the HA GUI (rather than running the script), but when I turn off the switch directly, rather than via the script, the command does actually work.
Maybe the error handling for the script is preventing the curl command from executing, whereas firing off the same curl command from the Switch panel on the GUI doesn’t?
