My cover.toggle is not working so i wanted to use this script I found online.
But I get the error: Message malformed: extra keys not allowed @ data[‘script’]
Where is that example located in your configuration?
If it is in scripts.yaml then it doesn’t need the first line containing script:
If you are creating the script using the Script Editor, then it also doesn’t need the first line containing script: and it may require modifying the second line.
That didn’t answer my question. I can’t help you until I know where you put all of that YAML code. I suspect you put it into the scripts.yaml file where it’s unnecessary to include what you have on the first line.
