I have a Script that turns on all of the lights and—for the ones that are dimmable—it gradually increases them from 1 to 255 and then stops.
alias: Fade On 2nd Floor Lights Group
sequence:
- variables:
start_brightness: 1
end_brightness: 255
brightness_increments: 3
duration_mins: 1
repeat_count: "{{ ((end_brightness - start_brightness) / brightness_increments) }}"
repeat_delay: "{{ ((duration_mins * 60) / repeat_count) }}"
- service: light.turn_on
brightness: "{{ start_brightness }}"
entity_id: light.2nd_floor_light_group
- delay:
hours: 0
minutes: 0
seconds: "{{ repeat_delay | int }} "
milliseconds: 0
- repeat:
while:
- condition: template
value_template: >-
{{ (state_attr('light.2nd_floor_light_group', 'brightness') <
end_brightness) }}
sequence:
brightness: >-
{{ state_attr('light.2nd_floor_light_group', 'brightness') | int +
brightness_increments }}
entity_id:
- light.2nd_floor_light_group
- delay:
hours: 0
minutes: 0
milliseconds: 0
mode: parallel
icon: mdi:lightbulb-multiple
max: 10
As long as I run it as a script, it works perfectly.
I am trying to call it from an Automation:
alias: " + When the time is equal to entity Input > Wake up time"
description: ""
- platform: time
at: input_datetime.wake_up_time
condition: []
- service: script.fade_on_2nd_floor_lights_group
data: {}
mode: parallel
When the Automation runs it only partially works. The non-dimmable lights turn on, the dimmable ones do not. According to the Traces, HA thinks it turned on the dimmable bulbs, but it did not.
Call a service 'Script: Fade On 1st Floor Lights Group' on
Fade On 1st Floor Lights Group (script.1701187248370) started
(script.1701187248370) turned on
(switch.wyze_cam_can_cam_power) turned off
(switch.bedroom_power_strip_02_usb_1) turned on
(light.turtle_lamp) turned on
(light.2nd_floor_light_group) turned on
(light.stairwell_overhead_02) turned on
(light.stairwell_overhead_lights) turned on
(switch.fairy_lights) turned on
(light.fairy_lights) turned on
(light.bedroom_table_lamp) turned on
(light.spare_bedroom_overhead) turned on
(light.corner_lamp) turned on
(switch.chest_lamp_socket_1) turned on
(light.stairwell_overhead_01) turned on
(light.chest_lamp) turned on
