I’m in the process of moving to the latest HA install which I now have installed & running ( 0.106.5) This is coming from an old install (0.72) where I’m now in the process of integrating my old working configs into the new install.
I have issues at the moment with two scripts where they are showing the same error when I do a test
Error executing script script.weather. Invalid data for call_service at pos 1: must contain at least one of entity_id, area_id.
The above error is from the below script which use to work
weather.yaml
alias: Weather
sequence:
- service: remote.send_command
command: Mute
device: 52435888
- service: tts.google_translate_say
data_template:
entity_id: media_player.kitchen_home
message: >
{% if now().strftime("%H")|int < 12 %}
Good morning.
{% elif now().strftime("%H")|int < 18 %}
Good afternoon.
{% else %}
Good evening.
{% endif %}
It's currently {{states.sensor.dark_sky_summary.state}} outdoors and {{states.sensor.temperature_158d0001e58873.state|round}} degrees indoors. Today will be {{states.sensor.dark_sky_hourly_summary.state|replace(".", "")}}, with a high of {{states.sensor.dark_sky_daytime_high_temperature.state|round}} degrees in Mansfield.
- delay:
seconds: 15
command: Mute
device: 52435888
I’m assuming you have gone to the scripts page on the HA website and compared your config to current listed? I assume you have also checked the Yamaha configs have also not changed?
