Hi there,
I’m trying to get my head around scripting and am stumped by an issue.
I have a script that I want to notify when a certain thing changes state.
I have this working for the most part. In so much as when the thing changes state, from either on to off or vice versa, it will trigger the script, notifications go out and are received etc, so all that is working.
However, on a subsequent event, nothing happens. The script seems to stop working. I’ve tried various modes like restart, queued, parralel etc, but all the same outcome.
If I happen to be in the Scripts screen on that script, i even see a banner appear saying “triggered” when the event happens, yet nothing is actioned.
The script is below:
pool_pump_listener:
alias: Pool Pump Listener
sequence:
- wait_for_trigger:
- platform: event
event_type: state_changed
event_data:
entity_id: light.fastled_ws2811_light
- service: notify.smtp_notifier
title: 'Notifier: Pool Pump'
message: Pool Pump has switched to {{ states.light.fastled_ws2811_light.state
- service: notify.mobile_app_pixel_4_xl
title: Notifier Pool Pump
mode: queued
icon: mdi:alarm-light
note: I’m just using the state of an LED for now to save turning a pool pump on/off constantly whilst testing this, just in case you are wondering what this is for - eventually I’ll use the switch.pool_pump entity that is actually what I’ll be watching.
After the script does it’s initial successful run, the Trace Timeline shows it as “Wait for Event Trigger”, however the time stamp on Step Details never updates again after subsequent triggers.
If I manually re-start the script it works again - once.
Here is the Step Details of a successful run:
Executed: July 27, 2022 at 2:07:52 PM
Result:
wait:
remaining: null
idx: '0'
platform: event
event:
old_state:
state: 'off'
attributes:
supported_color_modes:
- rgb
friendly_name: FastLED WS2811 Light
supported_features: 40
last_changed: '2022-07-27T04:06:35.767526+00:00'
last_updated: '2022-07-27T04:06:35.767526+00:00'
context:
parent_id: null
user_id: 946f3721c4e74ac5bbf3260a49b8db0e
new_state:
state: 'on'
attributes:
- rgb
color_mode: rgb
brightness: 255
hs_color:
- 120
- 100
rgb_color:
- 0
- 255
- 0
xy_color:
- 0.172
- 0.747
last_changed: '2022-07-27T04:07:55.239644+00:00'
last_updated: '2022-07-27T04:07:55.239644+00:00'
context:
parent_id: null
origin: LOCAL
time_fired: '2022-07-27T04:07:55.239644+00:00'
context:
parent_id: null
description: event 'state_changed'
Am I doing something wrong?
