i used the following configuration to make a test - the endpoint “http://192.168.0.82:2005/test” does not exist and causing a failure so the var set to 0 never happens. is there a way to make the script continue the sequence execution even if one of the calls along the way fails?
var:
test:
friendly_name: "Var Test"
rest_command:
rest_test:
url: http://192.168.0.82:2005/test
method: POST
script:
testing:
alias: test!
sequence:
- service: var.set
data_template:
entity_id: var.test
value: "1"
- service: rest_command.rest_test
- delay:
seconds: 30
- service: var.set
data_template:
entity_id: var.test
value: "0"
