Script or automation broke after upgrade to 2021.3.x
My automation which runs when my frezzer opens broke after upgrading til 2021.3.x.
It is supposed to run then the freezer is open repeating a message every 5 seconds.
I have tried to find the error - but can not. Hoping for some help? :slightly_smiling_face:
I get the error: “sonos_talk: Error executing script. Error for call_service at pos 4:”
The automation seems to be working fine - the script not so much for some reason.
My Automation:
- alias: 'Automation 48 - Freezer'
  mode: single
    platform: numeric_state
    entity_id: sensor.fibaro_system_fgbs222_smart_implant_burglar
    above: 1
    below: 4
  condition:
    - condition: and
      conditions:
      - condition: state
        entity_id: input_boolean.fryser
        state: 'on'
      - condition: time
        after: "07:30:00"
        before: "23:00:00"
    - alias: "Repeat freezer message"
      repeat:
        sequence:
          - service: script.sonos_talk
              sonos_entity: media_player.garage
              volume: 0.25
              message: "The freezer is open."
              delay1: '00:00:05'
        until:
          - condition: state
            state: '0'
My script:
script:
  sonos_talk:
    sequence:
      - service: sonos.snapshot
        data_template:
          entity_id: "{{ sonos_entity }}"
      - service: sonos.unjoin
        data_template:
      - service: media_player.volume_set
        data_template:
          volume_level: "{{ volume }}"
      - service: tts.google_say
        data_template:
          message: "{{ message }}"
      - delay: "{{ delay1 }}"
      - service: sonos.restore
        data_template:
That refers to this action in your script (the action/service positions start counting at 0):
I don’t see anything wrong. As a test try hard coding the delay to 5 seconds.
Thanks,
changed
to
- delay: "00:00:05"
Same error after reloading scripts.
Removes the linie
delay1: '00:00:05'
from the automation - same error (sonos_talk: Error executing script. Error for call_service at pos 4:)
Ok that’s not what I expected.
Tonight has been full of weird issues. Is it a full moon or something?
Create a new script and hard code all these variables:
script:
  sonos_talk:
    sequence:
        data_template:
        data_template:
        data_template:
        data_template:
        data_template:
See what happens.
No luck - keeps getting more and more weird
Automation:
  mode: single
    above: 1
    below: 4
  condition:
    - condition: and
      conditions:
      - condition: state
        state: 'on'
      - condition: time
        after: "07:30:00"
        before: "23:00:00"
      repeat:
        sequence:
#            data:
#               sonos_entity: media_player.garage
#               volume: 0.25
#               message: "The freezer is open."
#               delay1: '00:00:05'
        until:
          - condition: state
            state: '0'
Script:
script:
  sonos_talk:
    sequence:
        data_template:
          entity_id: "media_player.garage"
        data_template:
        data_template:
          volume_level: "0.25"
        data_template:
      - delay: "00:00:05"
        data_template:
Did a reboot - to be sure.
Error messages:
No. 1
Logger: homeassistant.components.script.sonos_talk
Source: helpers/script.py:1156
Integration: Script ([documentation](https://www.home-assistant.io/integrations/script), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+script%22))
First occurred: 19.05.29 (1 occurrences)
Last logged: 19.05.29
No 2
Logger: homeassistant.components.automation.automation_48_freezer
Integration: Automatisering ([documentation](https://www.home-assistant.io/integrations/automation), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+automation%22))
First occurred: 19.05.29 (2 occurrences)
* Automation 48 - Freezer: Repeat fryser besked: Error executing script. Error for call_service at pos 1:
* Automation 48 - Freezer: Error executing script. Error for repeat at pos 1:
No. 3
Source: components/automation/__init__.py:416
Integration: Automatisering (documentation, issues)
Error while executing automation automation.automation_48_freezer:
:blush:
tts was not working.
I had removed base_url from “http:” in configuration.yaml (some days ago) since it was deprecated. Had not seen it had to be added to “tts:” instead.
All is working.
@tom_l - thanks for you time and help on this “weird”-night :smiley: :muscle:
