I have forked and cloned the core repo to see how to add an integration, I’ve done the needed steps but when I get to generate an integration using script.scaffold, when it starts running the hassfest part, I get the following error:
I tried removing these 2 lines in the quality_scale.py and it worked after rerunning the command again, but I am not sure that it’s correct this way to remove these lines:
I had the same erorr today trying to create my development environment.
Running the script hassfest manually throws the following error:
Integration integration_name:
* [ERROR] [QUALITY_SCALE] Quality scale definition not found. New integrations are required to at least reach the Bronze tier.
I must be honest I don’t understand the change in development flow. You need a quality_scale.yaml file in your integration marking items as done. But I am not sure how it is not a circular dependency – I need to run hassfest script so I can test SSPD integration so I can complete the quality scale requirements but I need to complete the quality scale requirements before I can run the hassfest script. So in the meantime so I can continue working the content of my quality_scale.yaml file is :
rules:
# Bronze
action-setup:
status: exempt
comment: |
This integration is in development and requires a manifest for debugging purposes.
appropriate-polling:
status: exempt
comment: |
brands:
status: exempt
comment: |
common-modules:
status: exempt
comment: |
config-flow-test-coverage:
status: exempt
comment: |
config-flow:
status: exempt
comment: |
dependency-transparency:
status: exempt
comment: |
docs-actions:
status: exempt
comment: |
docs-high-level-description:
status: exempt
comment: |
docs-installation-instructions:
status: exempt
comment: |
docs-removal-instructions:
status: exempt
comment: |
entity-event-setup:
status: exempt
comment: |
entity-unique-id:
status: exempt
comment: |
has-entity-name:
status: exempt
comment: |
runtime-data:
status: exempt
comment: |
test-before-configure:
status: exempt
comment: |
test-before-setup:
status: exempt
comment: |
unique-config-entry:
status: exempt
comment: |
Well you need to a quaility_scale.yaml file in any case so might as well start with one Otherwise will probably just hit a brick wall later on in the process.
