Script Template Assistance
Writing a quick script for a new Dyson fan I picked up, but running into issues with the template, what am I doing wrong here?
bedroom_fan_night:
    alias: 'Bedroom Fan Night'
    sequence:
      - service: fan.set_speed
          entity_id: fan.bedroom
          speed: 2
      - service: fan.oscillate
          oscillating: true
      - service: climate.set_fan_mode
          entity_id: climate.bedroom
          fan_mode: "Focus Mode"
      - service: climate.set_temperature
        data_template:
          temperature: "{{ states('input_number.sleep_temp' ) |int }}"
          operation_mode: "{{ states('sensor.thermostat_mode') }}"
      - service: fan.dyson_set_night_mode
          night_mode: true
If I load up the Template Editor in the UI, both templates render just fine.
Guess it would help if I described what’s broken hu?! (thanks @petro)!
When the script gets run, all service entries run, like they should, except the one containing the template, the script literally skips it.
Cheers
What’s the exact problem?
The yaml format looks good and the templates look good. So pretty much need more information on
Hmm, it looks good. Turn on logging and watch the home assistant logs and verify that it’s not getting called. Check for errors too. When I say watch the logging, i’m refering to the home-assistant.log file inside the config directory. Don’t bother looking at the logs in the UI.
Try
        data_template:
          temperature: >
I am assuming there is no issue with the input_number.sleep_temp and sensor.thermostat_mode
Thanks guys, I’ll give both of those a try. Here’s what the templates render to, in the template editor:
ā€œ{{ states(ā€˜sensor.thermostat_mode’) }}ā€
ā€œ{{ states(ā€˜input_number.sleep_temp’ ) |int }}ā€
ā€œHeatā€
ā€œ65ā€
Think I found my problem…
This Works
climate.set_operation_mode
ā€œentity_idā€: ā€œclimate.bedroomā€,
ā€œoperation_modeā€: ā€œheatā€
This Does Not
ā€œoperation_modeā€: ā€œHeatā€
As listed above, the template returns ā€œHeatā€, not ā€œheatā€!
Anyone know the Jinja2 for converting case from upper to lower?
Then again, this also Works! (WTF)
ā€œtemperatureā€: ā€œ65ā€,
{{ "Heat".lower() }}
or
{{ "Heat" | lower }}
in your case:
"{{ states('sensor.thermostat_mode') | lower }}"
I’ve tried separating the 2 template options, to different steps, but that still didn’t work.
  bedroom_fan_night:
    sequence:
          speed: 2
          oscillating: true
      - service: climate.set_operation_mode
        data_template:
          operation_mode: "{{ states('sensor.thermostat_mode') |lower }}"
        data_template:
          night_mode: true
Going to add some more steps, with notifications, to see where it breaks.
Have you tried just calling the service from the service tab?
EDIT: Don’t use templates in this, they won’t work. Just use a normal json dict:
Service Data (JSON, optional)
{"entity_id":"climate.x", "operation_mode":"Heat"}
Yes, this does work (see 4 comments above).
This Works - and is done from the service tab
Lets see which ones fail, and which work:
  bedroom_fan_night_1:
    alias: 'Bedroom Fan Night 1'
    sequence:
          speed: 2
  bedroom_fan_night_2:
    alias: 'Bedroom Fan Night 2'
    sequence:
          speed: 2
          oscillating: true
  bedroom_fan_night_3:
    alias: 'Bedroom Fan Night 3'
    sequence:
          speed: 2
          oscillating: true
        data_template:
  bedroom_fan_night_4:
    alias: 'Bedroom Fan Night 4'
    sequence:
          speed: 2
          oscillating: true
        data_template:
        data_template:
I’m convinced there is something wrong with the component, or my specific fan (even though it works fine via the app).
The fan seems to do the specified action in the script, but is randomly and instantly reverted. For instance, I set it to cool, auto, and oscillate (which it did), then via a script I set it to a speed of 2 (and left everything else the same), It switched to 2, then immediately switched back to Auto.
I’m noticing the same behavior with every other version of the scripts I’m throwing at it.
Hate to revive something so old, but it’s still revellent.
Absolutely everything works in this script, as expected, except for the ā€œclimate.set_temperatureā€
  bedroom_fan_night_testing:
    alias: 'Bedroom Fan Night TEST'
    sequence:
          speed: "2"
      - delay: '00:00:01'
          oscillating: true
      - delay: '00:00:01'
        data_template:
          temperature: "65"
          operation_mode: "Heat"
      - delay: '00:00:05'
      - service: dyson.set_night_mode
          night_mode: true
I’ve also tried breaking out climate.set_temperature & climate.set_operation_mode, but the script still skips them, and continues on to dyson.set_night_mode.
If I open the actual component, and set the temp & mode, it works just fine.
40%20PM
Also, if I try and fire the climate.set_temperature & climate.set_operation_mode from Dev/Services, it fails as well (literally nothing happens, no logs, nothing).
Any ideas?
You’re using a service for the climate domain on a device in the fan domain. Sure you don’t have the correct entity_id?
EDIT: all your other posts call out climate.bedroom for your climate.set_temperatures
Thank you, that was it actually! Thought I was going nuts.
It seems this fan makes 2 different devices. fan.bedroom and climate.bedroom
fan.bedroom controls the fan, and climate.bedroom controls the heating, cooling, temp & operation modes. Wish that was better documented (Maybe I’ll go fix the docs so others don’t get stuck).
yeah it tripped me up too because it doesn’t really spell that out
For others with the Dyson Pure Hot+Cool:
(assuming your fan is named bedroom, for instance)
Use fan.bedroom for the following:
fan.oscillate
fan.set_direction
fan.set_speed
fan.toggle
fan.turn_on
fan.turn_off
Use climate.bedroom for the following:
climate.turn_on
climate.turn_off
I’m going to add a note in the component documentation as well.
My script for turning on the fan works, which is great. But I’ve run into an odd delema.
If you pass a temperature value to climate.set_temperature it automatically sets the operation_mode to heat, no matter if you manually set it to cool or not.
Currently I’m passing the temperature value to the fan as a template from my thermostat sleep temperature. As well as the operation_mode from my thermostat. This way thru out the year, when the script fires the temperature and operation_mode match that of my thermostat.
Works great in the winter, because it turns on the heat. But in the summer it also turns on the heat (even though cool is passed).
I’m wondering if I could use an if statement.
So IF the thermostat_mode is set to heat, call the service climate.set_temperature, with the temperature matching my thermostat temperature, and mode.
Else IF thermostat_mode is set to cool, call climate.set_operation_mode with a mode of cool, and speed of auto.
Here’s my current working script:
  bedroom_fan_night:
    sequence:
          speed: "2"
      - delay: '00:00:01'
          oscillating: true
      - delay: '00:00:01'
        data_template:
          operation_mode: "{{ states('sensor.thermostat_mode') | lower }}"
      - delay: '00:00:05'
          night_mode: true
