Basically I want a sequence that checks each TV and turns them off only if they are on.
Now since they are smart TVs I have created binary sensors to check if they are on, and I want to use the new broadlink switch module to turn them off, however the command is a toggle so I only want to call it IF the TV is already on.
I have been poking around at the condition formats which I don’t think will work because I want to check each TV not one TV in this script.
I also looked at the {% if %} syntax but nothing in the examples seems to fit.
Maybe you can use a sequence of scripts, and each script contains a condition to check if TV is ON.
Something like this:
automation:
- alias: "Turn TVs off"
your triggers here
service: script.turn_on
entity_id: script.check_tvs
script:
check_tvs
sequence:
- service: script.turn_on
entity_id: script.check_tv1
entity_id: script.check_tv2
check_tv1:
sequence:
- condition:
condition: state
entity_id: sensor.tv1
state: 'on'
- service: homeassistant.turn_off
entity_id: switch.tv_1
check_tv2:
sequence:
- condition:
condition: state
entity_id: sensor.tv2
state: 'on'
entity_id: switch.tv_2
I will give that a try, I thought condition blocks effected the WHOLE script not individual sequences.
Looks like this worked perfectly, realized after reading it that you where suggesting a script that calls two scripts.
I wish there was a slightly more syntactically efficient way to do this but it works.
I was looking for same solution as you. I can up with this. Slightly different. You just need one line in the automation to loop through all your script device checks.
automation:
- alias: 'Turn off all devices on'
- platform: state
entity_id: group.all_home
to: 'off'
entity_id: script.dev_checks
script:
dev_checks:
sequence:
- condition: template
value_template: '{{ states("switch.ac_lr_unit") != "off" }}'
- service: switch.turn_off
entity_id: switch.ac_lr_unit
entity_id: script.check_2
check_2:
sequence:
value_template: '{{ states("switch.ac_mr_unit") != "off" }}'
entity_id: switch.ac_mr_unit
entity_id: script.check_3
check_3:
sequence:
value_template: '{{ states("switch.sr_ac") != "off" }}'
- service: switch.turn_on
entity_id: switch.sr_ac
entity_id: script.check_4
check_4:
sequence:
value_template: '{{ states("switch.heat_seat") != "off" }}'
entity_id: switch.heat_seat
