had a few side-sessions with @NigelL, and this is the result for the ‘Ghosts’ script. Besides further tweaking and formatting, please note the great added functionality of disclosure of the group the ghosts are found in. Making this an indispensable tool for debugging your configuration.
# Script to find all grouped but non-existing entities
# https://community.home-assistant.io/t/script-to-find-items-that-no-longer-exist/56146/52
# original author: https://community.home-assistant.io/u/NigelL
# customizing, further tweaking and pushing it a bit by https://community.home-assistant.io/u/Mariusthvdb/
# set ignore_items and ignore_domains in the yaml file calling the script
# script:
# scan_ghosts:
# alias: Scan Ghosts
# sequence:
# - service: python_script.scan_ghosts
# data:
# ignore_items:
# - updater.updater
# - sensor.ghosts_sensor
# - sensor.ghosts_badge
# - sensor.orphans_sensor
# - sensor.orphans_badge
# - python_script.scan_for_orphans
# ignore_domains:
# - media_player
# - remote
# Codes for text_colors declared in
# Custom card: /custom_ui/state-card-value_only.html
# case "*": return "bold";
# case "/": return "italic";
# case "!": return "red";
# case "+": return "green";
# case "=": return "yellow";
# case "%": return "grey";
# case "$": return "brown";
# case "#": return "blue";
# default: return "normal";
def process_group_entities(group, grouped_entities, hass, logger, process_group_entities,\
processed_groups, ignore_domains, ignore_items):
# logger.info("processing group {}, currently {} grouped items".format(group.entity_id, len(grouped_entities)))
processed_groups.append(group.entity_id)
for e in group.attributes["entity_id"]:
domain = e.split(".")[0]
if domain == "group":
g = hass.states.get(e)
if (g is not None) and (g.entity_id not in processed_groups):
process_group_entities(g, grouped_entities, hass, logger, process_group_entities,\
else:
if (domain not in ignore_domains):
if not e in grouped_entities:
grouped_entities[e] = set()
grouped_entities[e].add(group.entity_id)
# logger.info("finishing group {}, currently {} grouped items".format(group.entity_id, \ len(grouped_entities)))
def scan_ghosts(hass, logger, data, process_group_entities):
target_group=data.get("target_group","group.ghosts")
show_as_view = data.get("show_as_view", False)
use_custom_ui = data.get("use_custom_ui", True)
ignore_items = data.get("ignore_items",[])
ignore_domains = data.get("ignore_domains",[])
real_entities = set(ignore_items)
grouped_entities = {}
processed_groups=[]
for s in hass.states.all():
domain = s.entity_id.split(".")[0]
if domain != "group":
real_entities.add(s.entity_id)
else:
if (("view" not in s.attributes) or
( s.attributes["view"] == False)):
process_group_entities(s,grouped_entities,hass,logger, \
process_group_entities,processed_groups,ignore_domains, \
ignore_items)
logger.info("{} real entities".format(len(real_entities)))
logger.info("{} grouped entities".format(len(grouped_entities)))
logger.info("{} groups processed".format(len(processed_groups)))
results = grouped_entities.keys() - real_entities
logger.info("{} entities to list".format(len(results)))
entity_ids=[]
# if (use_custom_ui): ## show card
busted=""
busted_badge=""
for e in results:
line = "{} in: {}".format(e, ",".join(grouped_entities[e]))
busted = "{}!- {}\n".format(busted,line)
busted_badge = "{}{}\n".format(busted_badge,line)
ignore_items_unlist = ', '.join(ignore_items)
ignore_domains_unlist = ', '.join(ignore_domains)
ghost_card = '*=========== Ghosts ===========\n' \
'{}\n' \
'*========= Entity count =========\n' \
'!- {} entities to list\n' \
'#- {} real entities\n' \
'+- {} grouped entities\n' \
'+- {} groups processed\n' \
'*========== Settings ===========\n' \
'/- targetting group: {}\n' \
'$- ignoring {} items:\n' \
'%|-> {}\n' \
'$- ignoring {} domains:\n' \
.format(busted,
len(results),
len(real_entities),
len(grouped_entities),
len(processed_groups),
target_group,
len(ignore_items),
ignore_items_unlist,
len(ignore_domains),
ignore_domains_unlist)
hass.states.set('sensor.ghosts_sensor', len(results), {
'custom_ui_state_card': 'state-card-value_only',
'text': ghost_card,
# 'unit_of_measurement': 'ghosts'
# else: ##show group with found ghosts:
counter=0
for e in results:
name = "left_entity.ghost{}".format(counter)
parent = "In: {}".format(",".join(grouped_entities[e]))
hass.states.set(name, parent, {"friendly_name":e, "icon": "mdi:ghost"})
entity_ids.append(name)
counter = counter +1
service_data = {'object_id': 'ghosts','name': 'Ghosts',
'view': show_as_view,'icon': 'mdi:ghost',
'control': 'hidden','entities': entity_ids,
'visible': True }
hass.services.call('group', 'set', service_data, False)
# show badge
hass.states.set('sensor.ghosts_badge', len(results), {
'text': busted_badge,
'unit_of_measurement': 'Ghosts',
'friendly_name': len(results),
'entity_picture': '/local/badges/ghosts.png'
Frontend:
