I have an Arduino ATTiny with a 315 Mhz transmitter that I can trigger as a switch from HA using a gpio pin connected to the ATTiny. The problem is that I want a momentary on or off signal so that the ATTiny transmitter isn’t continuously sending “on” or “off” or both. My goal is to use this wireless switch with automations.
I tried writing a script to send a momentary “on” but it doesn’t work.
switch:
platform: rpi_gpio
ports:
17: 315mhz_on
27: 315mhz_off
invert_logic: true
script:
315mhz_switch_on:
sequence:
service: rpi_gpio.315mhz_on
The code on the ATTiny is the following
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
const int onPin = 1;
const int offPin = 2;void setup()
// Transmitter is connected to Arduino Pin #5
mySwitch.enableTransmit(0);
mySwitch.setProtocol(2);
mySwitch.setPulseLength(800);
//mySwitch.setRepeatTransmit(10);digitalWrite(onPin,HIGH);
digitalWrite(offPin,HIGH);
}void loop()
int onval = digitalRead(onPin);
int offval = digitalRead(offPin);if (onval == LOW)
{mySwitch.send(53440 + 2, 17);
delay(5000);}if (offval == LOW)
{mySwitch.send(53280 + 2, 17);
delay(5000);}
