I see - now you have the same custom comp spotcast py files as I have…
What redirect URL do you use in Spotify Dev App?
In my case it is “https://my.home-assistant.io/redirect/oauth
I use the same:
Unfortunately, didn’t work for me either.
got three errors:
This error originated from a custom integration.
Logger: homeassistant
Source: custom_components/spotcast/spotcast_controller.py:126
Integration: Spotcast (documentation, issues)
First occurred: 22:09:36 (1 occurrences)
Last logged: 22:09:36
Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 484, in _async_run
return await self.script.async_run(script_vars, context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1524, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 409, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 453, in _async_step
self._handle_exception(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 476, in _handle_exception
raise exception
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 451, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 923, in _async_if_step
await self._async_run_script(if_data["if_then"])
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1029, in _async_run_script
await self._async_run_long_action(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 648, in _async_run_long_action
long_task.result()
raise exception
File "/usr/src/homeassistant/homeassistant/helpers/trace.py", line 252, in async_wrapper
await func(*args)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1025, in _async_parallel_step
raise result
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1017, in async_run_with_trace
await self._async_run_script(script)
long_task.result()
raise exception
long_task.result()
raise exception
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 896, in _async_choose_step
long_task.result()
raise exception
await func(*args)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 813, in _async_repeat_step
await async_run_sequence(iteration, extra_msg)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 795, in async_run_sequence
long_task.result()
raise exception
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 684, in _async_call_service_step
await service_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1745, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1788, in _execute_service
await self._hass.async_add_executor_job(
File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/config/custom_components/spotcast/__init__.py", line 190, in start_casting
spotify_device_id = spotcast_controller.get_spotify_device_id(
File "/config/custom_components/spotcast/spotcast_controller.py", line 243, in get_spotify_device_id
spotify_device_id = spotify_cast_device.getSpotifyDeviceId(
File "/config/custom_components/spotcast/spotcast_controller.py", line 126, in getSpotifyDeviceId
raise HomeAssistantError("Failed to get device id from Spotify")
homeassistant.exceptions.HomeAssistantError: Failed to get device id from Spotify
and
Logger: homeassistant.components.script.google_home_resume_helper
Source: helpers/script.py:409
Integration: Scripts (documentation, issues)
First occurred: 22:09:36 (6 occurrences)
00 - Google Home Resume - Helper Script: If at step 2: Parallel action at step 1: parallel 1: Resume needed?: Resume playing: Spotify?: Error executing script. Error for repeat at pos 2: Failed to get device id from Spotify
00 - Google Home Resume - Helper Script: If at step 2: Parallel action at step 1: parallel 1: Resume needed?: Error executing script. Error for choose at pos 2: Failed to get device id from Spotify
00 - Google Home Resume - Helper Script: If at step 2: Parallel action at step 1: parallel 1: Error executing script. Error for if at pos 9: Failed to get device id from Spotify
00 - Google Home Resume - Helper Script: If at step 2: Error executing script. Error for parallel at pos 1: Failed to get device id from Spotify
00 - Google Home Resume - Helper Script: Error executing script. Error for if at pos 2: Failed to get device id from Spotify
and
Logger: custom_components.spotcast.spotcast_controller
Source: custom_components/spotcast/spotcast_controller.py:243
First occurred: 22:09:36 (2 occurrences)
No device with id "9cded3903bad7e010cdf48e584193cf4" known by Spotify
Known devices: []
And the names of your devices in Home Assistant are exactly the same as in the Google Home app?
I just did a test with the non-primary account, which also worked fine. I’m a bit out of options here on why it works for me and not for you guys, I would suggest to maybe try the spotcast topic here on the HA community, or create an issue on the spotcast github.
The names are exactly the same.
OK, I will ask for help in spotcast topic.
Yes, the names are the same too. Hopefully, something transpires from the Spotcast topic.
from what I can tell, it seems that the custom integration cannot find your device that you have configured.
Well, as far as I understand it correctly it’s a bit like this:
But that’s about where my knowledge about how spotcast works stops
As the name is also shown as the source of the media_player of Spotify integration, I also use it to match the right Spotify media_player to the entity_id which is interrupted (in case multiple Spotify accounts are integrated)
Gotta say that this for the most part has worked flawlessly for me, thank you for all your efforts! I do have one question though… Basically I’m seeing that my TTS announcements are not matching the volume set in the scripts. Upon troubleshooting, I see the volume does get changed (to 20%), but then it immediately shoots back up to the previous volume before actually saying the announcement. This results in sound overlap from Google Homes in other rooms. Any help would be greatly appreciated!
notify_garage_interior_door_open:
alias: Notify - Garage Interior Door Open
sequence:
- service: media_player.volume_set
entity_id:
- media_player.living_room_speaker
- media_player.office_speaker_pair
- media_player.family_room_stereo_pair
volume_level: 0.2
- service: tts.google_say
entity_id: media_player.living_room_speaker
message: Garage Interior Door Open
cache: true
entity_id: media_player.family_room_stereo_pair
cache: true
entity_id: media_player.office_speaker_pair
cache: true
If you rely on the automation to start the resume script, you need to use the announce_volume_automation
setting. That is one generic setting which will be used for all announcements.
If you want to use different volume levels for different announcement, you need to call the resume script directly, and add the volume level there.
Thank you kindly for pointing me in the right direction. Turns out I just needed to remove the announce_volume_automation setting and add the resume script to my NodeRed flow. All is working great now!
sequence:
entity_id:
volume_level: 0.2
entity_id:
volume_level: 0.3
cache: true
cache: true
cache: true
Hey everyone, first off thanks to @TheFes for building this library, this looks exactly what I’ve been looking for for a while now. I’ve been trying to get this to work on my own now for a couple weeks, but have finally capitulated and created an account to ask for help on this forum.
I’m trying to do something fairly simple (I think) which is that when the mic from my work laptop goes to active I stop the music from my google home in my office. Then once the call is over I’d like to continue listening to the radio.
Pasting the automation below. It stops both tunein as well as spotify and I can see in the traces that it logs the information what had been playing at that time in the helpler script, but it simply never resumes. 20 secs after I hang up the script simply terminates, but doesn’t trigger the play media action. Any help is much appreciated, thanks in advance!
Automation:
alias: "Arbeitszimmer: Musik Pause wenn Teams call"
description: ""
- platform: state
entity_id: binary_sensor.microphoneactive
to: "on"
condition:
- condition: state
state: playing
entity_id: media_player.googlehome2011
- service: script.google_home_resume
- service: media_player.media_play
data: {}
mode: single
Sequence from logbook:
The script relies on actions performed on the Google Home, and you are not playing anything on it.
However, this is a good case for the Event script, which is also included in the package.
Let it store the data when the mic goes on, and resume when the mic goes off.
wow, thanks so much for the fast response! very much appreciated. also thanks for the pointer. I have now tried to set this up exactly the way you have laid it out in the docs with the leaving and coming home example. Unfortunately this neither paused the radio, nor resumed it (after pausing manually to test).
Would very much appreciate if you could add some more advice.
New automation:
description: ""
- platform: state
to: "on"
- platform: state
entity_id:
- binary_sensor.microphoneactive
to: "off"
condition: []
- choose:
- conditions:
- condition: trigger
- condition: device
device_id: 25bc5cf65f924937af5007d5a73d82f8
domain: media_player
type: is_playing
sequence:
- service: script.google_home_event
resume_id: resume_after_call
- conditions:
sequence:
resume: true
mode: single
I would remove the condition you added that the player should be playing. If it’s not, it will not be resumed as it was not playing.
Besides that I will need traces of the event script and resume script to see what’s going wrong here
Thanks for your support!
There is no trace from resume script. Event script trace uploaded here: { "trace": { "last_step": "sequence/2/choose/2/sequence/3", "run_id - Pastebin.com
Thanks!
Hmm, something is not going right here. Let me check if it works for myself…
Only a small update with some bugfixes right now
target_list
in case multiple targets are provided as stringtarget_list
which was not working if a target was specifiedcan you try 2023.1
I think that should resolve the issue
getting closer this paused the music, but still no resumption after hanging up. but we have traces for both google home event and google home resume now. pastebins below. once again thanks for looking into this!
pastebin google home event: { "trace": { "last_step": "sequence/2/choose/2/sequence/3", "run_id - Pastebin.com
pastebin google home resume: { "trace": { "last_step": "sequence/23/repeat/sequence/0", "run_id" - Pastebin.com
