Script to Toggle Cover
Hello everyone,
New to homeassitant, and got a question for you guys and gals…
I want to create a script that could toggle the cover when called. I understand that I can create one script to open, and one to close, using the sintax:
alias: Open Cover
service: cover.open_cover
  entity_id: cover.mqtt_cover
But I want to link this script to a IFTTT button on IOS, so ideally I just want one button, and if the garage is open I want the script to close the cover, if it is closed I want to to open it.
So the script needs to read the current status, and request the opposite… is it possible?
I think you can do this with templating based on the state but it would be a lot easier if cover had a toggle service like switch does.
There’s an example with a very similar topic here
Perfect!
Thanks! for future reference, if anybody needs to do the same the following worked fine for me:
script:
  toggle_cover:
    sequence:
      - service_template: >
          {% if is_state('cover.mqtt_cover', 'open') %}
            cover.close_cover
          {% else %}
            cover.open_cover
          {% endif %}
I knew it was done with a template; I just couldn’t remember the service template connection. Sorry!
Glad you got this solved.
Awesome stuff. Is there a way to integrate this into a MQTT Publish sequence? I have the following to create a MQTT Toggle button in MQTT Dash and it works extremely well but your template may well tidy that up even further.
### Closes garage door (if open) when publishing to display/kitchen/touch/garage ###
### with the payload as 'Closed' which matches the subscribe state in MQTT Dashboard ###
  - alias: MQTT Garage Close
    hide_entity: true
    condition:
      - condition: state
        entity_id: cover.garage
        state: 'open'
      - platform: mqtt
        topic: "display/kitchen/touch/garage"
        payload: "Closed"
      - service: cover.close_cover
### Opens garage door (if closed) when publishing to display/kitchen/touch/garage ###
### with the payload as 'Open' which matches the subscribe state in MQTT Dashboard ###
  - alias: MQTT Garage Open
    hide_entity: true
    condition:
      - condition: state
        state: 'closed'
      - platform: mqtt
        payload: "Open"
      - service: cover.open_cover
In case anyone is still wondering, you don’t need a script anymore
There is now a service cover.toggle
