Edited to add:
Whatever the case in my specific example. I would have thought that it would be ‘known’ (and maybe even documented somewhere) how a called script handles ‘missing’ variables. It seems like a fairly fundamental question.
I’m not convinced…
That seems sensible and the Template tool points to it being right but when I changed the script that had the typo that alerted me to this whole question it stopped working.
The scripts in question are non-trivial so I plan to write some simpler scripts to do some testing.
In the meantime,
With this, the script works but I have a feeling it has always worked through luck not judgement. ie.e I have always provided at least one sonos
{% if sonos != '' %}
{% for device in sonos -%}
media_player.sonos_{{ device }}{%- if not loop.last -%}, {% endif %}
{%- endfor %}
{% else %}
media_player.sonos_dining_room
{% endif %}
Whereas this didn’t seem to work at all (as I said I need to do more tetsing…)
{% if sonos != unknown %}
{%- endfor %}
{% else %}
{% endif %}
It looks to me like both of these work: {% if variable == unknown %}
or simply {% if variable %}
I tested using the following (results are shown at the bottom):
(I was slightly surprised to find that testing for is_number when no variable is passed causes an error. It is obviously an extremely artificial situation but surely the result should ‘False’?)
notify:
- platform: file
filename: my-log-testing.log
script:
test_passing_parameters:
sequence:
- service: script.test_receiving_parameters
string_var: This is a string
number_var: 1.5
test_receiving_parameters:
sequence:
- service: notify.log_announcements
message: >
string_var was passed in as *{{ string_var }}*
TEST: if "string_var != ''"
{% if string_var != '' -%}
TRUE
{% else -%}
FALSE
{% endif -%}
TEST: if "string_var == ''"
{% if string_var == '' -%}
TRUE
{% else -%}
FALSE
{% endif -%}
TEST: "if string_var"
{% if string_var -%}
TRUE
{% else -%}
FALSE
{% endif -%}
TEST: "if not string_var"
{% if not string_var -%}
TRUE
{% else -%}
FALSE
{% endif -%}
TEST: "if is_number(string_var)"
{% if is_number(string_var) -%}
TRUE
{% else -%}
FALSE
{% endif -%}
TEST: "if not string_var | length == 0"
{% if not is_number(string_var) -%}
TRUE
{% else -%}
FALSE
{% endif -%}
TEST: "if string_var | length != 0"
{% if string_var | length != 0 -%}
TRUE
{% else -%}
FALSE
{% endif -%}
TEST: "if string_var | length == 0"
{% if string_var | length == 0 -%}
TRUE
{% else -%}
FALSE
{% endif -%}
TEST: "if string_var != unknown"
{% if string_var != unknown -%}
TRUE
{% else -%}
FALSE
{% endif -%}
TEST: "if string_var == unknown"
{% if string_var == unknown -%}
TRUE
{% else -%}
FALSE
{% endif -%}
number_var was passed in as *{{ number_var }}*
NOTE: Testing for the length of a number causes an error
TEST: if "number_var != ''"
{% if number_var != '' -%}
TRUE
{% else -%}
FALSE
{% endif -%}
TEST: if "number_var == ''"
{% if number_var == '' -%}
TRUE
{% else -%}
FALSE
{% endif -%}
TEST: "if number_var"
{% if number_var -%}
TRUE
{% else -%}
FALSE
{% endif -%}
TEST: "if not number_var"
{% if not number_var -%}
TRUE
{% else -%}
FALSE
{% endif -%}
TEST: "if is_number(number_var)"
{% if is_number(number_var) -%}
TRUE
{% else -%}
FALSE
{% endif -%}
TEST: "if not is_number(number_var)"
{% if not is_number(number_var) -%}
TRUE
{% else -%}
FALSE
{% endif -%}
TEST: "if number_var != unknown"
{% if number_var != unknown -%}
TRUE
{% else -%}
FALSE
{% endif -%}
TEST: "if number_var == unknown"
{% if number_var == unknown -%}
TRUE
{% else -%}
FALSE
{% endif -%}
missing_var was passed in as *{{ missing_var }}*
NOTE: Testing for is_number causes an error
TEST: if "missing_var != ''"
{% if missing_var != '' -%}
TRUE
{% else -%}
FALSE
{% endif -%}
TEST: if "missing_var == ''"
{% if missing_var == '' -%}
TRUE
{% else -%}
FALSE
{% endif -%}
TEST: "if missing_var"
{% if missing_var -%}
TRUE
{% else -%}
FALSE
{% endif -%}
TEST: "if not missing_var"
{% if not missing_var -%}
TRUE
{% else -%}
FALSE
{% endif -%}
TEST: "if missing_var | length != 0"
{% if missing_var | length != 0 -%}
TRUE
{% else -%}
FALSE
{% endif -%}
TEST: "if missing_var | length == 0"
{% if missing_var | length == 0 -%}
TRUE
{% else -%}
FALSE
{% endif -%}
TEST: "if missing_var != unknown"
{% if missing_var != unknown -%}
TRUE
{% else -%}
FALSE
{% endif -%}
TEST: "if missing_var == unknown"
{% if missing_var == unknown -%}
TRUE
{% else -%}
FALSE
{% endif -%}
Which gave a log output as follows:
string_var was passed in as *This is a string*
TEST: if "string_var != ''" TRUE
TEST: if "string_var == ''" FALSE
TEST: "if string_var" TRUE
TEST: "if not string_var" FALSE
TEST: "if is_number(string_var)" FALSE
TEST: "if not string_var | length == 0" TRUE
TEST: "if string_var | length != 0" TRUE
TEST: "if string_var | length == 0" FALSE
TEST: "if string_var != unknown" TRUE
TEST: "if string_var == unknown" FALSE
number_var was passed in as *1.5*
TEST: if "number_var != ''" TRUE
TEST: if "number_var == ''" FALSE
TEST: "if number_var" TRUE
TEST: "if not number_var" FALSE
TEST: "if is_number(number_var)" TRUE
TEST: "if not is_number(number_var)" FALSE
TEST: "if number_var != unknown" TRUE
TEST: "if number_var == unknown" FALSE
missing_var was passed in as **
TEST: if "missing_var != ''" TRUE
TEST: if "missing_var == ''" FALSE
TEST: "if missing_var" FALSE
TEST: "if not missing_var" TRUE
TEST: "if missing_var | length != 0" FALSE
TEST: "if missing_var | length == 0" TRUE
TEST: "if missing_var != unknown" FALSE
TEST: "if missing_var == unknown" TRUE
