Script with 2 separate conditions
I wrote a script to basically shutdown the house when I leave. I have issue with the conditions and the garage doors. Basically, door 2 will only close if door 1 is also open. Anyone know how to have 2 separate conditions on one script?? thx
        lock_down:
    alias: Leave the house
    sequence:
      - service: homeassistant.turn_off
        entity_id: group.inside_lights
      - service: alarm_control_panel.alarm_arm_away
      - service: climate.set_away_mode
          entity_id: climate.hallway
          away_mode: true
# Close door 1 if open
      - condition: state
        entity_id: binary_sensor.garage_door_1
        state: 'on'
      - service: cover.close_cover
        entity_id: cover.garage_door_1
# Close door 2 if open
      - condition: state
        entity_id: binary_sensor.garage_door_2
        state: 'on'
        entity_id: cover.garage_door_2`
Yes. Move each set of condition and service into its own separate script, then call the two scripts from the original script. At least that’s how I did it.
Conditions and following actions will only keep running as long as each condition is true.
Once a single condition is false, the script stops.
Question: do you need to check if the binary_sensor.garage_door_1 is on to close the garage_door_1?
What happens if you try and close the door when it’s already closed?
If this is an issue, have you tried a service template?
- service_template: >
    {%- if is_state('binary_sensor.garage_door_1', 'on') -%}
    cover.close_cover
    {%- endif %}
Thanks everyone! This seems to work, it will turns off the inside lights, puts nest into away mode, sets the alarm panel to away and closes any OPEN garage doors. Cool…
lock_down:
    sequence:
          away_mode: true
      - service: script.close_door_1
      - service: script.close_door_2
close_door_1:
    alias: Closed Garage Door 1
# Close door 1 if open   '
    sequence:
      - condition: state
        state: 'on'
close_door_2:
    alias: Closed Garage Door 2
    sequence:
      - condition: state
        state: 'on'
