Okay, here it is:
"trace": {
"last_step": "sequence/0/else/0",
"run_id": "03ff71259163772bfccb4a8b242aba99",
"state": "stopped",
"script_execution": "finished",
"timestamp": {
"start": "2024-12-19T11:07:06.595465+00:00",
"finish": "2024-12-19T11:07:06.816706+00:00"
"domain": "script",
"item_id": "music_assistant_wiedergabe_starten",
"trace": {
"sequence/0": [
"path": "sequence/0",
"timestamp": "2024-12-19T11:07:06.595790+00:00",
"changed_variables": {
"this": {
"entity_id": "script.music_assistant_wiedergabe_starten",
"state": "off",
"attributes": {
"last_triggered": "2024-12-19T10:27:04.575234+00:00",
"mode": "restart",
"current": 0,
"icon": "mdi:music",
"friendly_name": "Music Assistant: Wiedergabe starten"
"last_changed": "2024-12-19T11:07:03.777148+00:00",
"last_reported": "2024-12-19T11:07:03.777148+00:00",
"last_updated": "2024-12-19T11:07:03.777148+00:00",
"context": {
"id": "01JFF9K1Q1Y4CEEPS25QJP2W8C",
"parent_id": null,
"user_id": null
"ID": "SWR3",
"type": "radio",
"device": "Soundbar",
"context": {
"id": "01JFF9K4F3WCNHTFPPDEYFV0TD",
"parent_id": null,
"user_id": "57ff779842184834a926e0fccf69c851"
"result": {
"choice": "else"
"sequence/0/if": [
"path": "sequence/0/if",
"timestamp": "2024-12-19T11:07:06.595934+00:00",
"result": {
"result": false
"sequence/0/if/condition/0": [
"path": "sequence/0/if/condition/0",
"timestamp": "2024-12-19T11:07:06.595960+00:00",
"result": {
"result": false,
"entities": []
"sequence/0/else/0": [
"path": "sequence/0/else/0",
"timestamp": "2024-12-19T11:07:06.596233+00:00",
"result": {
"params": {
"domain": "music_assistant",
"service": "play_media",
"service_data": {
"media_type": "radio",
"media_id": "SWR3",
"entity_id": [
"media_player.zipp_2_grau"
"target": {
"entity_id": [
"running_script": false
"config": {
"alias": "Music Assistant: Wiedergabe starten",
"sequence": [
"if": [
"condition": "template",
"value_template": "value_template: \"{{ device == 'Soundbar' }}\"",
"enabled": true
"then": [
"metadata": {},
"data": {
"media_type": "{{ type }}",
"media_id": "{{ ID }}"
"action": "music_assistant.play_media",
"target": {
"entity_id": "media_player.wohnzimmer_soundbar"
"else": [
"metadata": {},
"data": {
"target": {
"entity_id": "media_player.zipp_2_grau"
"enabled": true
"fields": {
"ID": {
"name": "MedienID",
"description": "Medien-ID (URL, Name des Elements zur Wiedergabe)",
"required": true,
"example": "SWR3"
"type": {
"name": "Medientyp",
"description": "Typ des abzuspielenden Inhaltes (Radio, Wiedergabeliste, ...)",
"required": true,
"example": "radio"
"device": {
"name": "Wiedergabegerät",
"description": "Wiedergabegerät auf dem abgespielt werden soll",
"required": true,
"example": "Soundbar"
"mode": "restart",
"description": ""
"blueprint_inputs": null,
"context": {
"parent_id": null,
"logbookEntries": [
"state": "on",
"when": 1734606426.595634,
"context_user_id": "57ff779842184834a926e0fccf69c851"
"state": "idle",
"entity_id": "media_player.zipp_2_grau",
"icon": "mdi:speaker",
"when": 1734606426.6214526,
"context_user_id": "57ff779842184834a926e0fccf69c851",
"context_state": "on",
"context_entity_id": "script.music_assistant_wiedergabe_starten"
"state": "off",
"when": 1734606426.8160057,
"state": "playing",
"when": 1734606427.4308136,
