Just sharing this solution.
The Commandline Cover, sets the cover (Somfy/RFLinkGW) and starts a script.
cover:
- platform: command_line
covers:
main_cover:
friendly_name: Shield
command_open: "echo -e '10;RTS;646566;1;UP;' > /dev/ttyACM0 ; /volume1/homeassistant/states.sh U"
command_close: "echo -e '10;RTS;646566;1;DOWN;' > /dev/ttyACM0 ; /volume1/homeassistant/states.sh D"
command_stop: "echo -e '10;RTS;646566;1;STOP;' > /dev/ttyACM0 ; /volume1/homeassistant/states.sh S"
command_state: "cat /volume1/homeassistant/coverstate.state"
The first script spawns a named screen session with the second script and detaches. If one already exists, it’s terminated.
states.sh:
screen -S HassCoverScreen -X quit ; screen -S HassCoverScreen -dm /volume1/homeassistant/statescount.sh $1 ; exit 0
The second script counts up or down to a file thats contains the state 0-100. As my cover takes 24 seconds to fully close or open, the script adds or removes 5 from the statefile every 1.2 seconds until 0 or 100 or when it gets terminated by the stop command.
statescount.sh:
state=$(cat /volume1/homeassistant/coverstate.state)
echo "Got state: $state"
if [ $state -lt "0" ] || [ $state -gt "100" ] ; then
echo "State is Fuckedup! Resetting to 50"
state=50
fi
if [ $1 = "U" ]; then
echo "Selected Up"
if [ $state = 100 ];
then
echo "Already Up dude!"
else
until [ $state -eq 100 ]; do
echo "Going Up: $state"
state=$((state+5))
echo $state > /volume1/homeassistant/coverstate.state
sleep 1.3
done
fi
fi
if [ $1 = "D" ]; then
echo "Selected Down"
if [ $state = 0 ];
then
echo "Already Down dude!"
else
until [ $state -eq 0 ]; do
echo "Going Down: $state"
state=$((state-5))
sleep 1.3
done
fi
fi
if [ $1 = "S" ]; then
echo "Stop"
fi
exit 0
It’s not perfect but it works.
