Im trying using a number helpers to set my bulb luminosity value from 0 to 100.
I created a input_number.luminosity and put it in my automation like this:
- platform: state
entity_id:
- binary_sensor.hallway_detection_zone_east
to: "on"
for:
hours: 0
minutes: 0
seconds: 0
condition: []
- service: light.turn_on
brightness_pct: '{{ states("input_number.hallway_luminosity_value") }}'
entity_id:
- light.hallway_light_east
mode: single
I also tried other different way to type it but It cant be detected. How do I put the value from that variable into the brightness_pct correctly?
Thank you
wait… is your input_number called input_number.luminosity? if so, try this?
- platform: state
entity_id:
to: "on"
for:
hours: 0
minutes: 0
seconds: 0
condition: []
brightness_pct: |
{{ states('input_number.luminosity') }}
entity_id:
mode: single
Whats the point of the | symbol?
I tried ur solution without the | symbol and it doesnt work. Using the | also doesnt work, I get “brightness_pct” need a float value
huh… try casting to a float?
In this particular case the | doesn’t do a ton… It does force it into template mode. if you don’t have the | and you put it on the same line, you will need to quote it to indicate it is a template, not a string. And you then need to double quote the quotes or be sure to use " instead of ’ to wrap the line… I avoid it all by using the | and putting the template on it’s own line
- platform: state
entity_id:
to: "on"
for:
hours: 0
minutes: 0
seconds: 0
condition: []
brightness_pct: |
{{ states('input_number.luminosity') | float }}
entity_id:
mode: single
If you continue to get an error, could you please post the code verbatim that gives you the float error.
don’t brother posting the code without the |
So I can try to make it work in template modded andd then copy paste easily. DIdnt know that.
Ended up with this:
brightness_pct: "{{ states('input_number.luminosity') | int }}"
and even if it is an INT it works as well. Thank you so much
awesome. glad you got it working! yes, the template modeling tool is a great way to work things out!! the services tab of dev tools is also very useful. you can test the action call and fiddle with it more quickly!
