If I have a script with a conditional line item, typically the script just stops if the condition is not met in accordance with this:
Is there a way to run a different action if a condition is not met? For example, if condition is not met, then a notification is sent instead of continuing on with the script.
This is my workaround on my home built garage door opener:
- service: script.garage_alarm_check
- condition: state
entity_id: input_boolean.mode_armed
state: ‘off’
I call a second script which checks to see if input_boolean.mode_armed is ON, and if so, sends a notification.
Then the main script checks the condition of the same input_boolean, but checks to see if its OFF so that it stops if not met (and a notification was already sent in the second script).
This works fine, just wondering if there is a way to simplify it.
