Here’s something I’ve been looking for an answer for sometime now. Why do some scripts display as a toggle switch (I assume this is to enable or disable the script) while others show the word ‘execute’ to run the script?
Is it possible to explicitly have the script display oneway or the other?
Oh right. Hadn’t thought of that. So I hit the toggle to on, then the script runs to the first break and switches itself off again? If I hit the toggle again, it picks up where it left off?
Is there a way to override it, so I can just have the ‘execute’ option?
Thanks, where do I put those lines? I’ve tried various parts of the entities card and haven’t got it to work. As an aside, the scripts show up as numbers.
Here’s what I’ve tried (well one of the options anyway).
If I’m reading this correctly, I should add this to the customize.yaml file (I have “customize: !include customize.yaml”) in my configuration.yaml file.
I’ve added:
script.1559882413231:
can_cancel: false
to customize.yaml, reloaded “location & customizations” it still displays with a toggle instead of “execute”. Restarted home assistant, no change.
I also tried to change the setting in the Customizations GUI, it just changes “false” back to “true”.
OK, I think I’ve found the problem. Turned out I had a duplicate key for the script in the customize.yaml, not picked up by the “check config” routine.
