Problem: The Automation which should stop the “dimming-loop” does not work everytime. I execute the automation on web-gui multiple times and then it works. The automation uses script.turn_off.
Is it possible, that there is bug in the software?
Nope, for the moment I gave up. My feeling is, that this problem has something to do with using an unvalidated extension for Hue – because otherwise the Dimmer-Switch would not be recognized. My feeling is, this extension may cause problems…
