Scripts not working since 2023.6
Has anyone else got an issue with script errors since 2023.6 upgrade?
I’m seeing the below in the script in entities for some reason:
And, when I check the logs, as to why the script didn’t execute I get the below, which strangely has an extra script. in front of the entity, so it shows script.script.. Maybe it’s always been like that but I don’t think so.
Logger: homeassistant.components.automation
Source: components/automation/config.py:207
Integration: Automation (documentation, issues)
First occurred: 6:32:19 AM (6 occurrences)
Last logged: 7:35:04 AM
Automation with alias 'Close Blinds' could not be validated and has been disabled: Service script.script.close_master_bedroom_blinds does not match format <domain>.<name> for dictionary value @ data['action'][1]['service']. Got 'script.script.close_master_bedroom_blinds'
Blueprint 'Philips Hue v2 Smart Dimmer Switch and Remote' generated invalid automation with inputs {'zha_device': 'bdd35051b552c9f46f2a42165e6fbab3', 'Power_Press': [{'service': 'light.turn_on', 'data': {'transition': 2, 'rgb_color': [247, 187, 84], 'brightness': 180}, 'target': {'entity_id': 'light.kitchen_lights_all'}}, {'service': 'switch.turn_off', 'data': [], 'target': {'entity_id': 'switch.kitchen_sensor_motion'}}], 'Power_Press2x': [{'service': 'light.turn_on', 'data': {'transition': 2, 'rgb_color': [247, 187, 84], 'brightness': 170}, 'target': {'entity_id': 'light.kitchen_lights_all'}}], 'Power_Press3x': [{'service': 'light.turn_on', 'data': {'transition': 2, 'rgb_color': [252, 252, 252], 'brightness': 231}, 'target': {'entity_id': 'light.kitchen_lights_all'}}], 'Power_Press4x': [{'service': 'light.turn_on', 'data': {'transition': 2, 'rgb_color': [252, 252, 252], 'brightness': 255}, 'target': {'entity_id': 'light.kitchen_lights_all'}}], 'Up_Press': [{'service': 'light.turn_on', 'data': {'transition': 0, 'brightness_step_pct': 1}, 'target': {'entity_id': 'light.kitchen_lights_all'}}], 'Down_Press': [{'service': 'light.turn_on', 'data': {'transition': 0, 'brightness_step': -1}, 'target': {'entity_id': 'light.kitchen_lights_all'}}], 'Hue_Press': [{'service': 'light.turn_off', 'data': {'transition': 4}, 'target': {'entity_id': 'light.kitchen_lights_all'}}, {'service': 'switch.turn_on', 'data': [], 'target': {'entity_id': 'switch.kitchen_sensor_motion'}}]}: template value should be a string for dictionary value @ data['action'][5]['choose'][0]['sequence'][1]['data']. Got []
Hi Martin, just a guess what you could try:
  • check your integrations (I had problems too after upgrading, another restart solved that)
  • try to run the sequences from the script separately
  • check if there is an update for that blueprint and if not, check/redo the the action part
Thanks Nick. The Close Blinds script runs fine when executed manually and I’ve restarted and even rebooted several times.
However, I hadn’t even spotted the reference to the blueprint until you mentioned it and that makes it even more curious because that particular blueprint has no relevance to the Close Blinds script.
I’ve just checked my automations.yaml and scripts.yaml and there is no link between the script and blueprint.
Can you post the automation ‘Close Blinds’
I spotted it. I added a new script to the actions yesterday and must have entered script.script accidentally. But, the automation calls 2 services and the error was in the second service call so the first one,service: script.close_downstairs_blinds should have run, shouldn’t it, then failed with the last one, or does it fail all actions?
Also, I still don’t get how the blueprint is being referenced when it is not linked to the automation.
This is my automation (corrected to remove the extra script. in front of the last action service):
- alias: Close Blinds
  mode: single
    platform: numeric_state
    entity_id: sun.sun
    attribute: elevation
    below: -0.4
  condition:
  - condition: state
    entity_id: sun.sun
    attribute: rising
    state: false
  - service: script.close_downstairs_blinds
  - service: script.close_master_bedroom_blinds
Forget the blueprint, that was a mistake from me.
The log also shows that the automation had been disabled because of that error.
Since you removed that and activate the automation again, it should work.
Thanks Nick.
Yes, that is a fairly recent and huge user-unfriendly regression in the way the syntax checker works.
the older behavior was that it would give you a notification in the sidebar that there was a problem and that you needed to check the logs for the error.
now it just silently fails and disables the automation without telling you unless you happen to notice the automation not triggering and happen to see the logbook entry.
it’s unfortunate that the devs have decided that this is the desired behavior for something as important for a home automation system as automations and claiming to be user friendly that new users need know to open the logbook to even know there is an issue that needs addressed.
I really don’t get it.
The automation editor does not let you save with those types of mistakes. And there still are errors in the logs related to these as long as you don’t restart. As soon as you restart, your previous logs are lost (Unless you look at the log history in your config folder) and the automation is already disabled (so it won’t generate the error again). The only change was the notification on the sidebar. That only affects YAML automation users who do not use the UI.
TLDR: You’ll see these errors if you use Yaml only automations in the UI, or you use the GUI UI. The errors are still in the logs but they wont be after it’s disabled and you restart.
I was not aware of any of that, thanks @finity @petro
I rarely use the GUI to create any automations or scripts etc but I’ll keep an eye out for this in future.
The only thing I ever do after creating/editing an automation is to do a config check and if it says it’s valid then I just reload automations. I don’t restart.
the config check doesn’t give a warning/notification that there is a problem with the automation. the system just disables the automation and puts an entry in the homeassistant.log with no other indication at all that there is a problem with the automation.
I’ve had this happen multiple times in the last few months with just a simple config error.
I guess I don’t see the purpose of removing the sidebar notification.
Same here. 100% yaml. If you test your automation with logs open, you’ll catch these errors immediately. The only reason it disables is because it was a service call error. If you mess up on an entity_id or service call data, it’ll just log the error in the logs without disabling the automation. That behavior hasn’t changed.
The whole system was reworked, it wasn’t a “Hey lets hurt the user by not having this notification”. Contrary to your belief, many of these changes are just overlooked accidentally.
Here is an issue that I submitted 3 weeks ago for it if anyone is interested:
It’s a bit crazy that something so integral to your smart home running efficiently does not have an ‘in your face’ warning that it’s not working (disabled).
Is there a way of creating a template to list all automations/scripts that are disabled? I have one each for devices and entities in a lovelace card but I wouldn’t know how to reference all automations/scripts. It’s not as if they are a device_class or anything.
I would prefer a warning at config check as well though.
Ah, just found one but not yet tested it.
{{ states.automation | selectattr('state', 'eq', 'off')
   | map(attribute='name') | list | join ('\n') }}
Much prefer a warning!
EDIT: Yes, it works. Better than nothing at this point. (credit for the automation here)
That’s not possible. At best the service slug can be validated, but it’s existence or not can’t be checked without the system running. This has always been a limitation of the config check. It only validates the yaml, it does not validate anything “deeper”. For that, you have to use the SSH config validation option or run the automation after reloading.
That’s a bit off topic though, that just seems like a bug with repeat. I looked at the code, it should be failing config check for that. I only looked at the surface though. There’s a function in there that might cause oddities.
I don’t think that will catch the issue with disabled automations that we are seeing.
as far as I’ve seen the disabled automation isn’t off - it’s not even included as an automation entity at all in the states list. If you look for that automation it doesn’t even exist as far the system is concerned.
That’s how I was able to know to look in the logs in the first place because the automation didn’t trigger and when I went looking for the trace the automation didn’t show up anywhere in the system. So I just looked to see if there was anything in the log and there it was.
I’m really sorry to have to keep adding to this thread and not addressing my points to anyone in particular…
the bug report was just an example of the failure that I was seeing. it wasn’t specifically about the repeat. it was about the error in the repeat not providing an invalid config check.
there have been many examples of this not only with the repeat. And not only from me. this thread is another example of that.
you would think that it should have given an invalid config check but it didn’t. it just failed silently with only an entry in the log and disabled the automation.
that is exactly the problem.
