Hey there,
I realized that since 0.115 my scripts start throwing exceptions in the logs and I’m not quite sure. I have two scripts that build a list and pass them to a python_script. But since 0.115 it seems to not like the “>” anymore:
2020-09-24 22:14:29 ERROR (MainThread) [homeassistant.components.automation.apartment_evening_time_close_roller_shutters_turn_on_lights] While executing automation automation.apartment_evening_time_close_roller_shutters_turn_on_lights
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 426, in async_trigger
await self.action_script.async_run(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 944, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 198, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 206, in _async_step
await getattr(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 552, in _async_choose_step
await self._async_run_script(script)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 626, in _async_run_script
await self._async_run_long_action(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 375, in _async_run_long_action
long_task.result()
await getattr(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 416, in _async_call_service_step
await self._async_run_long_action(service_task)
long_task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1315, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1350, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 215, in service_handler
await script_entity.async_turn_on(
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 320, in async_turn_on
await coro
await getattr(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 385, in _async_call_service_step
domain, service, service_data = async_prepare_call_from_config(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 138, in async_prepare_call_from_config
service_data.update(template.render_complex(config[conf], variables))
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 81, in render_complex
return {
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 82, in <dictcomp>
render_complex(key, variables): render_complex(item, variables)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 86, in render_complex
return value.async_render(variables)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 285, in async_render
return compiled.render(kwargs).strip()
File "/usr/local/lib/python3.8/site-packages/jinja2/environment.py", line 1090, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.8/site-packages/jinja2/environment.py", line 832, in handle_exception
reraise(*rewrite_traceback_stack(source=source))
File "/usr/local/lib/python3.8/site-packages/jinja2/_compat.py", line 28, in reraise
raise value.with_traceback(tb)
File "<template>", line 5, in top-level template code
TypeError: '>' not supported between instances of 'NoneType' and 'int'
That’s the one of the script throwing this error:
lights_set_effect_if_online:
sequence:
- service: python_script.lights_set_effect
data_template:
lights: >
{% set lights = namespace(list="") %}
{%- for light in ["light.bedroom_bedside_lamp_andy", "light.bedroom_bedside_lamp_kristina", "light.dining_room_pendant_light_ambilight", "light.living_room_ceiling_light_ambilight", "light.living_room_big_lamp", "light.living_room_small_lamp", "light.office_desk_lamp"] -%}
{%- if is_state(light, "on") -%}
{% set lights.list = lights.list + light + "," %}
{%- endif -%}
{%- endfor -%}
{{ lights.list }}
effect: "{{ effect }}"
That’s how it’s called in an automation:
- choose:
- conditions:
- condition: state
entity_id: group.everybody
state: home
sequence:
- scene: scene.living_room_tv_mode
- delay: 00:00:01
- service: script.lights_set_effect_if_online
effect: "Evening Time"
- delay: 00:00:05
- service: script.close_roller_shutters
default:
I checked the Blog post and the breaking changes section, but I couldn’t find something about that.
Is this a bug or am I hitting another breaking change that was introduced in an earlier release?
Thanks and greetings,
Andy!
