I am having a weird issue where no scripts will load from script.yaml or script folder, was working fine yesterday. The only change was upgrading to .68. He is one script (the only one I have in the script.yaml file) which I copied from syntax example:
test_script:
sequence:
# This is written using the Script Syntax
- service: light.turn_on
entity_id: group.lights_dimmer
And in my config yaml:
script: !include script.yaml
If I create in UI (when there is a scripts.yaml file) it works fine.
I have treid everything I can think of at this point, including recreating python venv.
Yeah, basically exactly where you linked to. The problem tends to be that people don’t notice the difference between a listed multiple entry and a named multiple entry, so they don’t understand what the options mean and therefore which one they need.
The former bit is correct, it returns the contents of the directory, you just need to return it as a list (for components that need lists) or names (for components that need names).
