Scrypted installation error - no such image?
I am following the guide here and getting below error, any ideas?
Logger: homeassistant.components.hassio
Source: components/hassio/websocket_api.py:138
Integration: Home Assistant Supervisor (documentation, issues)
First occurred: 01:20:28 (1 occurrences)
Last logged: 01:20:28
Failed to to call /addons/09e60fb6_scrypted/install - Can’t install ghcr.io/koush/scrypted:18-jammy-full.s6-v0.80.0: 404 Client Error for http+docker://localhost/v1.43/images/ghcr.io/koush/scrypted:18-jammy-full.s6-v0.80.0/json: Not Found (“No such image: ghcr.io/koush/scrypted:18-jammy-full.s6-v0.80.0”)
Due to a fairly recent change to the directory structure in HA Core, Many add-ons need to make changes. Please write an issue in that github (after you look for one) would be my suggestion.
Thank you James, I will.
