I’m beginning on ESPHOME, no on HA and I would like to use my SDS011 with ESPHOME.
After installed my ESPHOME on docker, I create a new device (based on Nodemcu) and I completed my config file for the SDS011 (as you see below), compile and flash my nodemcu with the bin file. But when I add my esphome on HA, the state through from available to unknow but my nodemcu is correctly connect and I don’t understand why it doesn’t work. Could you help me ?
For information, I listen the SDS011 fan work each 5 minutes and I don’t have more information on my log and I tried to invert my pin (D7 and D8 to try) and it’s the same with D6 and D7 (with change the config file and upload of course)
I use an ESP32 for this but should be the same i think.
Don’t know if it helps (maybe you already tried it) but i found that the RX pin of the SDS011 needs to be connected to the RX of my ESP32 (Not the TX, that you would expect). And de TX needs to go to TX.
I use UART0 for that on GPIO1 (ESP32 - TX) and GPIO3 (ESP32 - RX).
