SDS011 not updating at specified interval
Hello All,
I have two devices with identical hardware except one has an I2C SH1106 display while the other has no display. The other devices are:
  • NodeMCU CP2102 ESP-12E
  • SDS011 Air Quality Sensor
  • DHT11 Temp/Humidity sensor
The configs are also the same except for the ‘name’ parameters and the display stuff for the one that has the display.
Problem is the SDS011 on the device with no display updates every minute even though the config specifies an update interval of 10 minutes.
This is the config for the device that’s incorrectly getting the air quality values every minute.
esphome:
  platform: ESP8266
  board: esp12e
# Enable logging
logger:
# Enable Home Assistant API
api:
 password: !secret haapi_password
ota:
  password: !secret ota_password
wifi:
  networks:
  - ssid: !secret wifi1_ssid
    password: !secret wifi1_password
  - ssid: !secret wifi2_ssid
    password: !secret wifi2_password
  manual_ip:
    static_ip: x.x.x.x
    gateway: x.x.x.x
    subnet: x.x.x.x
    dns1: x.x.x.x
    dns2: x.x.x.x
  fast_connect: off
  ap:
    ssid: "Downstairs Fallback"
    password: !secret fb_password
captive_portal:
switch:
  - platform: restart
time:
  - platform: homeassistant
uart:
  rx_pin: GPIO12
  tx_pin: GPIO14
  baud_rate: 9600
- platform: dht
  pin: GPIO13
  update_interval: 60s
  temperature:
    name: "Downstairs Temperature"
    force_update: true
    filters:
    - filter_out: nan
    - sliding_window_moving_average:
        window_size: 15
        send_every: 1
        send_first_at: 1
  humidity:
    name: "Downstairs Humidity"
    force_update: true
    filters:
    - filter_out: nan
        window_size: 15
        send_every: 1
        send_first_at: 1
# DHT Filtering should be sending averaged values every 60 Seconds
- platform: sds011
  update_interval: 10min
  pm_2_5:
    name: "Downstairs PM <2.5µm"
  pm_10_0:
    name: "Downstairs PM <10.0µm"
  name: "Downstairs PM <2.5µm 1 Hour Avg"
  unit_of_measurement: 'µg/m³'
  state_class: measurement
  icon: mdi:chemical-weapon
  lambda: |-
    return (id(PM25).state);
  filters:
  - filter_out: nan
      window_size: 6
      send_every: 1
      send_first_at: 1
  name: "Downstairs PM <2.5µm 24 Hour Avg"
  update_interval: 60min
  lambda: |-
    return (id(PM251Hour).state);
  filters:
  - filter_out: nan
      window_size: 24
      send_every: 1
      send_first_at: 1
  name: "Downstairs PM <10.0µm 1 Hour Avg"
  lambda: |-
    return (id(PM100).state);
  filters:
  - filter_out: nan
      window_size: 6
      send_every: 1
      send_first_at: 1
  name: "Downstairs PM <10.0µm 24 Hour Avg"
  lambda: |-
    return (id(PM1001Hour).state);
  filters:
  - filter_out: nan
      window_size: 24
      send_every: 1
      send_first_at: 1
  name: "Downstairs PM2.5µm 24 Hour AQI"
  unit_of_measurement: 'AQI'
  accuracy_decimals: 1
  lambda: |-
    if ((id(PM2524Hour).state) > 300.0)
    { return round((((500.0 - 301.0)/(500.4 - 250.5)) * ((id(PM2524Hour).state) - 250.5) + 301.0));
    else if ((id(PM2524Hour).state) > 200.0 and (id(PM2524Hour).state) <= 300.0)
    { return round((((300.0 - 201.0)/(250.4 - 150.5)) * ((id(PM2524Hour).state) - 150.5) + 201.0));
    else if ((id(PM2524Hour).state) > 150.0 and (id(PM2524Hour).state) <= 200.0)
    { return round((((200.0 - 151.0)/(150.4 - 55.5)) * ((id(PM2524Hour).state) - 55.5) + 151.0));
    else if ((id(PM2524Hour).state) > 100.0 and (id(PM2524Hour).state) <= 150.0)
    { return round((((150.0 - 101.0)/(55.4 - 35.5)) * ((id(PM2524Hour).state) - 35.5) + 101.0));
    else if ((id(PM2524Hour).state) > 50.0 and (id(PM2524Hour).state) <= 100.0)
    { return round((((100.0 - 51.0)/(35.4 - 12.1)) * ((id(PM2524Hour).state) - 12.1) + 51.0));
    else
    { return round((((50.0 - 0.0)/(12.0 - 0.0)) * ((id(PM2524Hour).state) - 0.0) + 0.0));
  name: "Downstairs PM10.0µm 24 Hour AQI"
  lambda: |-
    if ((id(PM10024Hour).state) > 300.0)
    { return round((((500.0 - 301.0)/(500.4 - 250.5)) * ((id(PM10024Hour).state) - 250.5) + 301.0));
    else if ((id(PM10024Hour).state) > 200.0 and (id(PM10024Hour).state) <= 300.0)
    { return round((((300.0 - 201.0)/(250.4 - 150.5)) * ((id(PM10024Hour).state) - 150.5) + 201.0));
    else if ((id(PM10024Hour).state) > 150.0 and (id(PM10024Hour).state) <= 200.0)
    { return round((((200.0 - 151.0)/(150.4 - 55.5)) * ((id(PM10024Hour).state) - 55.5) + 151.0));
    else if ((id(PM10024Hour).state) > 100.0 and (id(PM10024Hour).state) <= 150.0)
    { return round((((150.0 - 101.0)/(55.4 - 35.5)) * ((id(PM10024Hour).state) - 35.5) + 101.0));
    else if ((id(PM10024Hour).state) > 50.0 and (id(PM10024Hour).state) <= 100.0)
    { return round((((100.0 - 51.0)/(35.4 - 12.1)) * ((id(PM10024Hour).state) - 12.1) + 51.0));
    else
    { return round((((50.0 - 0.0)/(12.0 - 0.0)) * ((id(PM10024Hour).state) - 0.0) + 0.0));
  name: "Downstairs PM10.0µm 1 Hour AQI"
  lambda: |-
    if ((id(PM1001Hour).state) > 300.0)
    { return round((((500.0 - 301.0)/(500.4 - 250.5)) * ((id(PM1001Hour).state) - 250.5) + 301.0));
    else if ((id(PM1001Hour).state) > 200.0 and (id(PM1001Hour).state) <= 300.0)
    { return round((((300.0 - 201.0)/(250.4 - 150.5)) * ((id(PM1001Hour).state) - 150.5) + 201.0));
    else if ((id(PM1001Hour).state) > 150.0 and (id(PM1001Hour).state) <= 200.0)
    { return round((((200.0 - 151.0)/(150.4 - 55.5)) * ((id(PM1001Hour).state) - 55.5) + 151.0));
    else if ((id(PM1001Hour).state) > 100.0 and (id(PM1001Hour).state) <= 150.0)
    { return round((((150.0 - 101.0)/(55.4 - 35.5)) * ((id(PM1001Hour).state) - 35.5) + 101.0));
    else if ((id(PM1001Hour).state) > 50.0 and (id(PM1001Hour).state) <= 100.0)
    { return round((((100.0 - 51.0)/(35.4 - 12.1)) * ((id(PM1001Hour).state) - 12.1) + 51.0));
    else
    { return round((((50.0 - 0.0)/(12.0 - 0.0)) * ((id(PM1001Hour).state) - 0.0) + 0.0));
  name: "Downstairs PM2.5µm 1 Hour AQI"
  lambda: |-
    if ((id(PM251Hour).state) > 300.0)
    { return round((((500.0 - 301.0)/(500.4 - 250.5)) * ((id(PM251Hour).state) - 250.5) + 301.0));
    else if ((id(PM251Hour).state) > 200.0 and (id(PM251Hour).state) <= 300.0)
    { return round((((300.0 - 201.0)/(250.4 - 150.5)) * ((id(PM251Hour).state) - 150.5) + 201.0));
    else if ((id(PM251Hour).state) > 150.0 and (id(PM251Hour).state) <= 200.0)
    { return round((((200.0 - 151.0)/(150.4 - 55.5)) * ((id(PM251Hour).state) - 55.5) + 151.0));
    else if ((id(PM251Hour).state) > 100.0 and (id(PM251Hour).state) <= 150.0)
    { return round((((150.0 - 101.0)/(55.4 - 35.5)) * ((id(PM251Hour).state) - 35.5) + 101.0));
    else if ((id(PM251Hour).state) > 50.0 and (id(PM251Hour).state) <= 100.0)
    { return round((((100.0 - 51.0)/(35.4 - 12.1)) * ((id(PM251Hour).state) - 12.1) + 51.0));
    else
    { return round((((50.0 - 0.0)/(12.0 - 0.0)) * ((id(PM251Hour).state) - 0.0) + 0.0));
text_sensor:
  name: "Downstairs PM2.5µm 1 Hour AQI Index"
  lambda: |-
    if ((id(SDS011_PM25_1Hour_AQI).state) > 300.0)
    { return {"Hazardous"};
    else if ((id(SDS011_PM25_1Hour_AQI).state) > 200.0 and (id(SDS011_PM25_1Hour_AQI).state) <= 300.0)
    { return {"Very Unhealthy"};
    else if ((id(SDS011_PM25_1Hour_AQI).state) > 150.0 and (id(SDS011_PM25_1Hour_AQI).state) <= 200.0)
    { return {"Unhealthy"};
    else if ((id(SDS011_PM25_1Hour_AQI).state) > 100.0 and (id(SDS011_PM25_1Hour_AQI).state) <= 150.0)
    { return {"Unhealthy for Sensitive Groups"};
    else if ((id(SDS011_PM25_1Hour_AQI).state) > 50.0 and (id(SDS011_PM25_1Hour_AQI).state) <= 100.0)
    { return {"Moderate"};
    else
    { return {"Good"};
  name: "Downstairs PM2.5µm 24 Hour AQI Index"
  lambda: |-
    if ((id(SDS011_PM25_AQI).state) > 300.0)
    else if ((id(SDS011_PM25_AQI).state) > 200.0 and (id(SDS011_PM25_AQI).state) <= 300.0)
    else if ((id(SDS011_PM25_AQI).state) > 150.0 and (id(SDS011_PM25_AQI).state) <= 200.0)
    else if ((id(SDS011_PM25_AQI).state) > 100.0 and (id(SDS011_PM25_AQI).state) <= 150.0)
    else if ((id(SDS011_PM25_AQI).state) > 50.0 and (id(SDS011_PM25_AQI).state) <= 100.0)
    else
    { return {"Good"};
  name: "Downstairs PM10.0µm 1 Hour AQI Index"
  lambda: |-
    if ((id(SDS011_PM100_1Hour_AQI).state) > 300.0)
    else if ((id(SDS011_PM100_1Hour_AQI).state) > 200.0 and (id(SDS011_PM100_1Hour_AQI).state) <= 300.0)
    else if ((id(SDS011_PM100_1Hour_AQI).state) > 150.0 and (id(SDS011_PM100_1Hour_AQI).state) <= 200.0)
    else if ((id(SDS011_PM100_1Hour_AQI).state) > 100.0 and (id(SDS011_PM100_1Hour_AQI).state) <= 150.0)
    else if ((id(SDS011_PM100_1Hour_AQI).state) > 50.0 and (id(SDS011_PM100_1Hour_AQI).state) <= 100.0)
    else
    { return {"Good"};
  name: "Downstairs PM10.0µm 24 Hour AQI Index"
  lambda: |-
    if ((id(SDS011_PM100_AQI).state) > 300.0)
    else if ((id(SDS011_PM100_AQI).state) > 200.0 and (id(SDS011_PM100_AQI).state) <= 300.0)
    else if ((id(SDS011_PM100_AQI).state) > 150.0 and (id(SDS011_PM100_AQI).state) <= 200.0)
    else if ((id(SDS011_PM100_AQI).state) > 100.0 and (id(SDS011_PM100_AQI).state) <= 150.0)
    else if ((id(SDS011_PM100_AQI).state) > 50.0 and (id(SDS011_PM100_AQI).state) <= 100.0)
    else
    { return {"Good"};
- platform: wifi_info
  ip_address:
    name: Downstairs IP Address
  ssid:
    name: Downstairs Connected SSID
  bssid:
    name: Downstairs Connected BSSID
  mac_address:
    name: Downstairs Mac Wifi Address
And a few log entries showing the SDS updating every minute.
[10:27:19][C][wifi_info:009]: WifiInfo IPAddress 'Downstairs IP Address'
[10:27:19][C][wifi_info:010]: WifiInfo SSID 'Downstairs Connected SSID'
[10:27:19][C][wifi_info:011]: WifiInfo BSSID 'Downstairs Connected BSSID'
[10:27:54][D][dht:048]: Got Temperature=25.5°C Humidity=31.0%
[10:27:54][D][sensor:131]: 'Downstairs Temperature': Sending state 25.50000 °C with 1 decimals of accuracy
[10:27:54][D][sensor:131]: 'Downstairs Humidity': Sending state 31.00000 % with 0 decimals of accuracy
[10:28:01][D][sds011:169]: Got PM2.5 Concentration: 3.7 µg/m³, PM10.0 Concentration: 8.3 µg/m³
[10:28:01][D][sensor:131]: 'Downstairs PM <2.5µm': Sending state 3.70000 µg/m³ with 1 decimals of accuracy
[10:28:01][D][sensor:131]: 'Downstairs PM <10.0µm': Sending state 8.30000 µg/m³ with 1 decimals of accuracy
[10:28:54][D][dht:048]: Got Temperature=25.8°C Humidity=31.0%
[10:28:54][D][sensor:131]: 'Downstairs Temperature': Sending state 25.65000 °C with 1 decimals of accuracy
[10:28:54][D][sensor:131]: 'Downstairs Humidity': Sending state 31.00000 % with 0 decimals of accuracy
[10:29:01][D][sds011:169]: Got PM2.5 Concentration: 4.0 µg/m³, PM10.0 Concentration: 9.3 µg/m³
[10:29:01][D][sensor:131]: 'Downstairs PM <2.5µm': Sending state 4.00000 µg/m³ with 1 decimals of accuracy
[10:29:01][D][sensor:131]: 'Downstairs PM <10.0µm': Sending state 9.30000 µg/m³ with 1 decimals of accuracy
And the config for the device that updates at the correct 10 minute interval
esphome:
  platform: ESP8266
  board: esp12e
# Enable logging
logger:
api:
ota:
wifi:
  networks:
  manual_ip:
    static_ip: x.x.x.x
    gateway: x.x.x.x
    subnet: x.x.x.x
    dns1: x.x.x.x
    dns2: x.x.x.x
  fast_connect: off
  ap:
    ssid: "TestnodeMCU Fallback"
captive_portal:
switch:
  - platform: restart
i2c:
  sda: GPIO4
  scl: GPIO5
time:
uart:
  rx_pin: GPIO12
  tx_pin: GPIO14
  baud_rate: 9600
- platform: dht
  pin: GPIO13
  temperature:
    name: "NodeMCU Temperature"
    force_update: true
    filters:
    - filter_out: nan
        window_size: 15
        send_every: 1
        send_first_at: 1
  humidity:
    name: "NodeMCU Humidity"
    force_update: true
    filters:
    - filter_out: nan
        window_size: 15
        send_every: 1
        send_first_at: 1
- platform: sds011
  pm_2_5:
  pm_10_0:
  name: "PM <2.5µm 1 Hour Avg"
  lambda: |-
  filters:
  - filter_out: nan
      window_size: 6
      send_every: 1
      send_first_at: 1
  name: "PM <2.5µm 24 Hour Avg"
  lambda: |-
  filters:
  - filter_out: nan
      window_size: 24
      send_every: 1
      send_first_at: 1
  name: "PM <10.0µm 1 Hour Avg"
  lambda: |-
  filters:
  - filter_out: nan
      window_size: 6
      send_every: 1
      send_first_at: 1
  name: "PM <10.0µm 24 Hour Avg"
  lambda: |-
  filters:
  - filter_out: nan
      window_size: 24
      send_every: 1
      send_first_at: 1
  name: "PM2.5µm 24 Hour AQI"
  lambda: |-
    else
  name: "PM10.0µm 24 Hour AQI"
  lambda: |-
    else
  name: "PM10.0µm 1 Hour AQI"
  lambda: |-
    else
  name: "PM2.5µm 1 Hour AQI"
  lambda: |-
    else
text_sensor:
  name: "PM2.5µm 1 Hour AQI Index"
  lambda: |-
    else
    { return {"Good"};
  name: "PM2.5µm 24 Hour AQI Index"
  lambda: |-
    else
    { return {"Good"};
  name: "PM10.0µm 1 Hour AQI Index"
  lambda: |-
    else
    { return {"Good"};
  name: "PM10.0µm 24 Hour AQI Index"
  lambda: |-
    else
    { return {"Good"};
  ip_address:
    name: NodeMCU IP Address
  ssid:
    name: NodeMCU Connected SSID
  bssid:
    name: NodeMCU Connected BSSID
  mac_address:
    name: NodeMCU Mac Wifi Address
font:
  - file: "fonts/Calibri Regular.ttf"
display:
  - platform: ssd1306_i2c
    model: "SH1106 128x64"
    address: 0x3C
    brightness: 20%
    external_vcc: true
    update_interval: 5s
    lambda: |-
      it.printf(1, 1, id(calibri_16), "Temp: %.1f°", ((id(temperatureC).state * 1.8) + 32.0));
      it.printf(1,16, id(calibri_16), "Humidity: %.1f%%", id(humidity).state);
      it.printf(1,32, id(calibri_16), "PM 2.5: %.1f", id(PM25).state);
      it.printf(1,48, id(calibri_16), "PM 10.0: %.1f", id(PM100).state);
Any ideas as to why?
Hi.
I have no experience with the sds011, but according to documentation. The update_interval is sent to the sensor by the uart. The sensor can work in only rx mode.
So maybe it fails to set the update_intervall by the tx pin.
The things that you could check is the connection to the sensor.
Loose cable, wrong pin/GPIO on the tx.
I could also be a bug or faulty sensor but that is harder to check.
I hope you find it.
/Mattias
thanks! I had exactly this issue. Turned out that my RX connection on the sensor side was loose. After fixing it and re-installing firmware (first with update_interval: 0min and subsequently again with update_interval 10min) it worked.
I couldn’t set the update interval via ESP. But I was able to do it using the Windows application. Perhaps, to make the program work, you will have to install VC Redist 2010 x86 and enable compatibility with Windows 8.
https://www.open-electronics.org/sds011-the-air-quality-sensor/
https://futuranet.it/futurashop/image/catalog/data/Download/Laser%2BPM2.5%2BSensor%2BSoftware%2BV1.88.rar
EDIT: The next day, after the sensor was turned off overnight, it went back to the default setting. Additional observations are needed.
