Hello All,
I have two devices with identical hardware except one has an I2C SH1106 display while the other has no display. The other devices are:
- NodeMCU CP2102 ESP-12E
- SDS011 Air Quality Sensor
- DHT11 Temp/Humidity sensor
The configs are also the same except for the ‘name’ parameters and the display stuff for the one that has the display.
Problem is the SDS011 on the device with no display updates every minute even though the config specifies an update interval of 10 minutes.
This is the config for the device that’s incorrectly getting the air quality values every minute.
esphome:
platform: ESP8266
board: esp12e
# Enable logging
logger:
# Enable Home Assistant API
api:
password: !secret haapi_password
ota:
password: !secret ota_password
wifi:
networks:
- ssid: !secret wifi1_ssid
password: !secret wifi1_password
- ssid: !secret wifi2_ssid
password: !secret wifi2_password
manual_ip:
static_ip: x.x.x.x
gateway: x.x.x.x
subnet: x.x.x.x
dns1: x.x.x.x
dns2: x.x.x.x
fast_connect: off
ap:
ssid: "Downstairs Fallback"
password: !secret fb_password
captive_portal:
switch:
- platform: restart
time:
- platform: homeassistant
uart:
rx_pin: GPIO12
tx_pin: GPIO14
baud_rate: 9600
- platform: dht
pin: GPIO13
update_interval: 60s
temperature:
name: "Downstairs Temperature"
force_update: true
filters:
- filter_out: nan
- sliding_window_moving_average:
window_size: 15
send_every: 1
send_first_at: 1
humidity:
name: "Downstairs Humidity"
force_update: true
filters:
- filter_out: nan
window_size: 15
send_every: 1
send_first_at: 1
# DHT Filtering should be sending averaged values every 60 Seconds
- platform: sds011
update_interval: 10min
pm_2_5:
name: "Downstairs PM <2.5µm"
pm_10_0:
name: "Downstairs PM <10.0µm"
name: "Downstairs PM <2.5µm 1 Hour Avg"
unit_of_measurement: 'µg/m³'
state_class: measurement
icon: mdi:chemical-weapon
lambda: |-
return (id(PM25).state);
filters:
- filter_out: nan
window_size: 6
send_every: 1
send_first_at: 1
name: "Downstairs PM <2.5µm 24 Hour Avg"
update_interval: 60min
lambda: |-
return (id(PM251Hour).state);
filters:
- filter_out: nan
window_size: 24
send_every: 1
send_first_at: 1
name: "Downstairs PM <10.0µm 1 Hour Avg"
lambda: |-
return (id(PM100).state);
filters:
- filter_out: nan
window_size: 6
send_every: 1
send_first_at: 1
name: "Downstairs PM <10.0µm 24 Hour Avg"
lambda: |-
return (id(PM1001Hour).state);
filters:
- filter_out: nan
window_size: 24
send_every: 1
send_first_at: 1
name: "Downstairs PM2.5µm 24 Hour AQI"
unit_of_measurement: 'AQI'
accuracy_decimals: 1
lambda: |-
if ((id(PM2524Hour).state) > 300.0)
{ return round((((500.0 - 301.0)/(500.4 - 250.5)) * ((id(PM2524Hour).state) - 250.5) + 301.0));
else if ((id(PM2524Hour).state) > 200.0 and (id(PM2524Hour).state) <= 300.0)
{ return round((((300.0 - 201.0)/(250.4 - 150.5)) * ((id(PM2524Hour).state) - 150.5) + 201.0));
else if ((id(PM2524Hour).state) > 150.0 and (id(PM2524Hour).state) <= 200.0)
{ return round((((200.0 - 151.0)/(150.4 - 55.5)) * ((id(PM2524Hour).state) - 55.5) + 151.0));
else if ((id(PM2524Hour).state) > 100.0 and (id(PM2524Hour).state) <= 150.0)
{ return round((((150.0 - 101.0)/(55.4 - 35.5)) * ((id(PM2524Hour).state) - 35.5) + 101.0));
else if ((id(PM2524Hour).state) > 50.0 and (id(PM2524Hour).state) <= 100.0)
{ return round((((100.0 - 51.0)/(35.4 - 12.1)) * ((id(PM2524Hour).state) - 12.1) + 51.0));
else
{ return round((((50.0 - 0.0)/(12.0 - 0.0)) * ((id(PM2524Hour).state) - 0.0) + 0.0));
name: "Downstairs PM10.0µm 24 Hour AQI"
lambda: |-
if ((id(PM10024Hour).state) > 300.0)
{ return round((((500.0 - 301.0)/(500.4 - 250.5)) * ((id(PM10024Hour).state) - 250.5) + 301.0));
else if ((id(PM10024Hour).state) > 200.0 and (id(PM10024Hour).state) <= 300.0)
{ return round((((300.0 - 201.0)/(250.4 - 150.5)) * ((id(PM10024Hour).state) - 150.5) + 201.0));
else if ((id(PM10024Hour).state) > 150.0 and (id(PM10024Hour).state) <= 200.0)
{ return round((((200.0 - 151.0)/(150.4 - 55.5)) * ((id(PM10024Hour).state) - 55.5) + 151.0));
else if ((id(PM10024Hour).state) > 100.0 and (id(PM10024Hour).state) <= 150.0)
{ return round((((150.0 - 101.0)/(55.4 - 35.5)) * ((id(PM10024Hour).state) - 35.5) + 101.0));
else if ((id(PM10024Hour).state) > 50.0 and (id(PM10024Hour).state) <= 100.0)
{ return round((((100.0 - 51.0)/(35.4 - 12.1)) * ((id(PM10024Hour).state) - 12.1) + 51.0));
else
{ return round((((50.0 - 0.0)/(12.0 - 0.0)) * ((id(PM10024Hour).state) - 0.0) + 0.0));
name: "Downstairs PM10.0µm 1 Hour AQI"
lambda: |-
if ((id(PM1001Hour).state) > 300.0)
{ return round((((500.0 - 301.0)/(500.4 - 250.5)) * ((id(PM1001Hour).state) - 250.5) + 301.0));
else if ((id(PM1001Hour).state) > 200.0 and (id(PM1001Hour).state) <= 300.0)
{ return round((((300.0 - 201.0)/(250.4 - 150.5)) * ((id(PM1001Hour).state) - 150.5) + 201.0));
else if ((id(PM1001Hour).state) > 150.0 and (id(PM1001Hour).state) <= 200.0)
{ return round((((200.0 - 151.0)/(150.4 - 55.5)) * ((id(PM1001Hour).state) - 55.5) + 151.0));
else if ((id(PM1001Hour).state) > 100.0 and (id(PM1001Hour).state) <= 150.0)
{ return round((((150.0 - 101.0)/(55.4 - 35.5)) * ((id(PM1001Hour).state) - 35.5) + 101.0));
else if ((id(PM1001Hour).state) > 50.0 and (id(PM1001Hour).state) <= 100.0)
{ return round((((100.0 - 51.0)/(35.4 - 12.1)) * ((id(PM1001Hour).state) - 12.1) + 51.0));
else
{ return round((((50.0 - 0.0)/(12.0 - 0.0)) * ((id(PM1001Hour).state) - 0.0) + 0.0));
name: "Downstairs PM2.5µm 1 Hour AQI"
lambda: |-
if ((id(PM251Hour).state) > 300.0)
{ return round((((500.0 - 301.0)/(500.4 - 250.5)) * ((id(PM251Hour).state) - 250.5) + 301.0));
else if ((id(PM251Hour).state) > 200.0 and (id(PM251Hour).state) <= 300.0)
{ return round((((300.0 - 201.0)/(250.4 - 150.5)) * ((id(PM251Hour).state) - 150.5) + 201.0));
else if ((id(PM251Hour).state) > 150.0 and (id(PM251Hour).state) <= 200.0)
{ return round((((200.0 - 151.0)/(150.4 - 55.5)) * ((id(PM251Hour).state) - 55.5) + 151.0));
else if ((id(PM251Hour).state) > 100.0 and (id(PM251Hour).state) <= 150.0)
{ return round((((150.0 - 101.0)/(55.4 - 35.5)) * ((id(PM251Hour).state) - 35.5) + 101.0));
else if ((id(PM251Hour).state) > 50.0 and (id(PM251Hour).state) <= 100.0)
{ return round((((100.0 - 51.0)/(35.4 - 12.1)) * ((id(PM251Hour).state) - 12.1) + 51.0));
else
{ return round((((50.0 - 0.0)/(12.0 - 0.0)) * ((id(PM251Hour).state) - 0.0) + 0.0));
text_sensor:
name: "Downstairs PM2.5µm 1 Hour AQI Index"
lambda: |-
if ((id(SDS011_PM25_1Hour_AQI).state) > 300.0)
{ return {"Hazardous"};
else if ((id(SDS011_PM25_1Hour_AQI).state) > 200.0 and (id(SDS011_PM25_1Hour_AQI).state) <= 300.0)
{ return {"Very Unhealthy"};
else if ((id(SDS011_PM25_1Hour_AQI).state) > 150.0 and (id(SDS011_PM25_1Hour_AQI).state) <= 200.0)
{ return {"Unhealthy"};
else if ((id(SDS011_PM25_1Hour_AQI).state) > 100.0 and (id(SDS011_PM25_1Hour_AQI).state) <= 150.0)
{ return {"Unhealthy for Sensitive Groups"};
else if ((id(SDS011_PM25_1Hour_AQI).state) > 50.0 and (id(SDS011_PM25_1Hour_AQI).state) <= 100.0)
{ return {"Moderate"};
else
{ return {"Good"};
name: "Downstairs PM2.5µm 24 Hour AQI Index"
lambda: |-
if ((id(SDS011_PM25_AQI).state) > 300.0)
else if ((id(SDS011_PM25_AQI).state) > 200.0 and (id(SDS011_PM25_AQI).state) <= 300.0)
else if ((id(SDS011_PM25_AQI).state) > 150.0 and (id(SDS011_PM25_AQI).state) <= 200.0)
else if ((id(SDS011_PM25_AQI).state) > 100.0 and (id(SDS011_PM25_AQI).state) <= 150.0)
else if ((id(SDS011_PM25_AQI).state) > 50.0 and (id(SDS011_PM25_AQI).state) <= 100.0)
else
{ return {"Good"};
name: "Downstairs PM10.0µm 1 Hour AQI Index"
lambda: |-
if ((id(SDS011_PM100_1Hour_AQI).state) > 300.0)
else if ((id(SDS011_PM100_1Hour_AQI).state) > 200.0 and (id(SDS011_PM100_1Hour_AQI).state) <= 300.0)
else if ((id(SDS011_PM100_1Hour_AQI).state) > 150.0 and (id(SDS011_PM100_1Hour_AQI).state) <= 200.0)
else if ((id(SDS011_PM100_1Hour_AQI).state) > 100.0 and (id(SDS011_PM100_1Hour_AQI).state) <= 150.0)
else if ((id(SDS011_PM100_1Hour_AQI).state) > 50.0 and (id(SDS011_PM100_1Hour_AQI).state) <= 100.0)
else
{ return {"Good"};
name: "Downstairs PM10.0µm 24 Hour AQI Index"
lambda: |-
if ((id(SDS011_PM100_AQI).state) > 300.0)
else if ((id(SDS011_PM100_AQI).state) > 200.0 and (id(SDS011_PM100_AQI).state) <= 300.0)
else if ((id(SDS011_PM100_AQI).state) > 150.0 and (id(SDS011_PM100_AQI).state) <= 200.0)
else if ((id(SDS011_PM100_AQI).state) > 100.0 and (id(SDS011_PM100_AQI).state) <= 150.0)
else if ((id(SDS011_PM100_AQI).state) > 50.0 and (id(SDS011_PM100_AQI).state) <= 100.0)
else
{ return {"Good"};
- platform: wifi_info
ip_address:
name: Downstairs IP Address
ssid:
name: Downstairs Connected SSID
bssid:
name: Downstairs Connected BSSID
mac_address:
name: Downstairs Mac Wifi Address
And a few log entries showing the SDS updating every minute.
[10:27:19][C][wifi_info:009]: WifiInfo IPAddress 'Downstairs IP Address'
[10:27:19][C][wifi_info:010]: WifiInfo SSID 'Downstairs Connected SSID'
[10:27:19][C][wifi_info:011]: WifiInfo BSSID 'Downstairs Connected BSSID'
[10:27:54][D][dht:048]: Got Temperature=25.5°C Humidity=31.0%
[10:27:54][D][sensor:131]: 'Downstairs Temperature': Sending state 25.50000 °C with 1 decimals of accuracy
[10:27:54][D][sensor:131]: 'Downstairs Humidity': Sending state 31.00000 % with 0 decimals of accuracy
[10:28:01][D][sds011:169]: Got PM2.5 Concentration: 3.7 µg/m³, PM10.0 Concentration: 8.3 µg/m³
[10:28:01][D][sensor:131]: 'Downstairs PM <2.5µm': Sending state 3.70000 µg/m³ with 1 decimals of accuracy
[10:28:01][D][sensor:131]: 'Downstairs PM <10.0µm': Sending state 8.30000 µg/m³ with 1 decimals of accuracy
[10:28:54][D][dht:048]: Got Temperature=25.8°C Humidity=31.0%
[10:28:54][D][sensor:131]: 'Downstairs Temperature': Sending state 25.65000 °C with 1 decimals of accuracy
[10:28:54][D][sensor:131]: 'Downstairs Humidity': Sending state 31.00000 % with 0 decimals of accuracy
[10:29:01][D][sds011:169]: Got PM2.5 Concentration: 4.0 µg/m³, PM10.0 Concentration: 9.3 µg/m³
[10:29:01][D][sensor:131]: 'Downstairs PM <2.5µm': Sending state 4.00000 µg/m³ with 1 decimals of accuracy
[10:29:01][D][sensor:131]: 'Downstairs PM <10.0µm': Sending state 9.30000 µg/m³ with 1 decimals of accuracy
And the config for the device that updates at the correct 10 minute interval
esphome:
platform: ESP8266
board: esp12e
# Enable logging
logger:
api:
ota:
wifi:
networks:
manual_ip:
static_ip: x.x.x.x
gateway: x.x.x.x
subnet: x.x.x.x
dns1: x.x.x.x
dns2: x.x.x.x
fast_connect: off
ap:
ssid: "TestnodeMCU Fallback"
captive_portal:
switch:
- platform: restart
i2c:
sda: GPIO4
scl: GPIO5
time:
uart:
rx_pin: GPIO12
tx_pin: GPIO14
baud_rate: 9600
- platform: dht
pin: GPIO13
temperature:
name: "NodeMCU Temperature"
force_update: true
filters:
- filter_out: nan
window_size: 15
send_every: 1
send_first_at: 1
humidity:
name: "NodeMCU Humidity"
force_update: true
filters:
- filter_out: nan
window_size: 15
send_every: 1
send_first_at: 1
- platform: sds011
pm_2_5:
pm_10_0:
name: "PM <2.5µm 1 Hour Avg"
lambda: |-
filters:
- filter_out: nan
window_size: 6
send_every: 1
send_first_at: 1
name: "PM <2.5µm 24 Hour Avg"
lambda: |-
filters:
- filter_out: nan
window_size: 24
send_every: 1
send_first_at: 1
name: "PM <10.0µm 1 Hour Avg"
lambda: |-
filters:
- filter_out: nan
window_size: 6
send_every: 1
send_first_at: 1
name: "PM <10.0µm 24 Hour Avg"
lambda: |-
filters:
- filter_out: nan
window_size: 24
send_every: 1
send_first_at: 1
name: "PM2.5µm 24 Hour AQI"
lambda: |-
else
name: "PM10.0µm 24 Hour AQI"
lambda: |-
else
name: "PM10.0µm 1 Hour AQI"
lambda: |-
else
name: "PM2.5µm 1 Hour AQI"
lambda: |-
else
text_sensor:
name: "PM2.5µm 1 Hour AQI Index"
lambda: |-
else
{ return {"Good"};
name: "PM2.5µm 24 Hour AQI Index"
lambda: |-
else
{ return {"Good"};
name: "PM10.0µm 1 Hour AQI Index"
lambda: |-
else
{ return {"Good"};
name: "PM10.0µm 24 Hour AQI Index"
lambda: |-
else
{ return {"Good"};
ip_address:
name: NodeMCU IP Address
ssid:
name: NodeMCU Connected SSID
bssid:
name: NodeMCU Connected BSSID
mac_address:
name: NodeMCU Mac Wifi Address
font:
- file: "fonts/Calibri Regular.ttf"
display:
- platform: ssd1306_i2c
model: "SH1106 128x64"
address: 0x3C
brightness: 20%
external_vcc: true
update_interval: 5s
lambda: |-
it.printf(1, 1, id(calibri_16), "Temp: %.1f°", ((id(temperatureC).state * 1.8) + 32.0));
it.printf(1,16, id(calibri_16), "Humidity: %.1f%%", id(humidity).state);
it.printf(1,32, id(calibri_16), "PM 2.5: %.1f", id(PM25).state);
it.printf(1,48, id(calibri_16), "PM 10.0: %.1f", id(PM100).state);
Any ideas as to why?
