Hi there,
The title says it all.
Find an adapter that can also measure current. Does anyone have a recommendation for my above configuration?
Greetings Werner
Hi there,
Greetings Werner
Except where you live, which is rather important for a power plug
Oh sorry.
Germany / EU
Personally i don’t have any zigbee plugs but if you havn’t already then i recommend this part of the ZHA guide. Also this link in that section might help too.
Cheers
Nick
Hi there,
I had already seen that. However, the list is far too short and sometimes not correct.
Hence my question for a recommendation based on experience.
Greetings Werner
I use Xiaomi (semi-cheap) and Tuya (cheap) with no issue. They only report power, not energy (maybe a ZHA issue) but that’s not an issue with HA with the rieman integration.
Just bough those that work fine:
Vielen Dank. Werde ich mal testen.
So, @Herbert01 - what did you end up using? Im also looking to measure the consumption on a few always pluged in devices such as oven, dish washer, dryer, tv…
A friend is using AVM DECT smart plugs but only because they were gifted to him.
This one works fine for me:
Neat. Thanks!
This got me into an aliexpress rabithole that ended at https://athom.tech they offer esphome preflased plugs that are the same model as tuja and others.
Wifi, but esphome …
FYI, those devices are using Wi-Fi and not using Zigbee (which this thread + forum is specifically about).
I use Aqara plug. I have changed to Z2M, however pretty sure they also report energy and current on ZHA.
The Blackadder site shows a lot of information about different zigbee devices, however not always fully updated on functionality.
Zigbee2MQTT supported devices list more details on capabilities each device exposes, inc. current:
https://www.zigbee2mqtt.io/supported-devices/ → https://www.zigbee2mqtt.io/supported-devices/#e=current
