Search in list from state
I use a rest sensor to retrieve a list but I cannot search in this list. I can if I write this list manually.
Here is the output of my template.
{% set mystatelist = states.sensor.anniversaires.state %}
{{ mystatelist }}
{{ mystatelist.0 }}
Search in list from variable
{% set myvariablelist = {'event1': 'Anniversaire', 'date': '2021-06-04'},{'event2': 'Anniversaire', 'date': '2021-06-05'},{'event3': 'Anniversaire', 'date': '2021-06-08'}%}
{{ myvariablelist }}
{{ myvariablelist.0 }}
({'event1': 'Anniversaire', 'date': '2021-06-04'}, {'event2': 'Anniversaire', 'date': '2021-06-05'}, {'event3': 'Anniversaire', 'date': '2021-06-08'})
Am I doing something wrong ?
A list should look like this: ["a", "b", "c"]. None of your examples is a list: the manually-written one has turned into a Python tuple — a bit like a list but in parentheses ("a", "b", "c") and the indexing does work.
You should have written it like this:
{% set myvariablelist = [{'event1': 'Anniversaire', 'date': '2021-06-04'},{'event2': 'Anniversaire', 'date': '2021-06-05'},{'event3': 'Anniversaire', 'date': '2021-06-08'}] %}
What does states('sensor.anniversaires') return? How about states('sensor.anniversaires')[0]?
{{ states('sensor.anniversaires') }}
returns
but
{{ states('sensor.anniversaires')[0] }}
returns
Thanks for your help.
Of course: it’s a string (like all sensor states), trying to represent a JSON object but uses single quotes rather than double. Try this:
{{ (states('sensor.anniversaires').replace("'",'"')|from_json)[0] }}
This takes the state string, replaces all the single quotes with doubles, converts to JSON, then reads the first item.
It works, thanks !
