Searching for a dual channel wall mounted dual white dimmer
In an existing lamp, I want to place 2 (or more) dimmable (dump) light bulbs with different colour temperature.
With adjusting 1 of the dim values, the temperature should be set, when both are adjusted, the brightness should be set.
The controlling should be possible with a wall mounted dimmer, because I want to avoid using apps all the time, and it should be possible to operate the lights even if the wifi is down.
(see image below).
Smart Home
So far I’m having troubles to find a proper dimmer for this, and I’am hoping there is someone who can give me advice on this
Thanks in advance
